HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-03-2009, 10:22 AM   #11 (permalink)
BigD23's Avatar
Default Re: NEW BX25 comming.. What upgrades do I want?
One thing you need to add is Lots of FEL/BH/BB time...Congrats on your new tractor!
Don
BigD23 is offline   Reply With Quote
Old 07-03-2009, 11:19 AM   #12 (permalink)
Gold Member
Singlecoil's Avatar
The cheapest upgrade you can make is to replace the key-chain type rings that the 3 point kit comes with to secure the kit to the tractor's lift arms with easier to use clips. The rings are a pain in the neck to take on and off. I'm assuming the setup is the same as on my BX-24. I replaced them with these:
__________________
Keep your friends close, your enemies closer, and your neighbors as far away as possible.
Kubota BX-24, Rankin 48" box scraper, Rankin 601 PHD, Bro-Tek rear skid plate, Bro-Tek thumb, Bro-Tek ripper tooth with trencher, Farm Force 60" rake, LandPride RCR-1548 Rotary Cutter.
Singlecoil is offline   Reply With Quote
Old 07-03-2009, 04:54 PM   #13 (permalink)
Gold Member
Ken_CT's Avatar
Congratulations on the new machine. You might want to have them weld a couple of hooks on the FEL. I have one grab hook in the middle, and find it very useful. BTW, I think the ripper is great, especially for roots and picking rocks from the lawn.
Ken
Ken_CT is offline   Reply With Quote
Old 07-03-2009, 11:58 PM   #14 (permalink)
New Member
Man that is a big rock... I am should be getting the tractor Monday. I am also trying to talk them down on a Land Pride PHD. I have got them down to $850 so far, but would like to spend around $650 for it.... Guess I will find out how cheap I can get it on Monday.
hevnbnd is offline   Reply With Quote
Old 07-04-2009, 04:06 AM   #15 (permalink)
Toothbar for FEL is only $200 or so, Markham is most popular manufacturer.
Bucket hooks for FEL and BH are inexpensive, a thread in archives has numerous ideas. There are weld on, bolt on; I drilled holes in FEL bucket sides and put HD spring clips in when needed. Hooks also vary depending on whether it is a chain hook or slip hook (for nylon straps). Obviously chain and/or straps to go with this.
If you have the MMM, Larry @ MowerAxle has storage wheels that let you turn the deck vertically and roll it into storage. They are inexpensive.
A big funnel with filter can be helpful when fueling. I have a 17" dia. funnel that I got from a racing supply store. You also need to decide whether you're going to get 3 or so 5 gal. yellow diesel canisters by Blitz, or perhaps a "fueling station" of which N. H. Northern Tool and Supply carries several. I am currently designing/building a little boom arm which will quickly/easily clip to ROPS and support 5 gal. fuel canister while I tip and pour fuel.
Virtually all my implements are on dollies that I custom made for each one. Makes changing implements infinitely easier.
If you live where it freezes, you need to keep some extra Super UDT on hand. If it never freezes where you live, then you should keep some regular UDT on hand (both are made by Kubota and are superior hydro oil-they are the same except that the "super" has an additive to prevent gelling in cold weather-and costs more). I took a 5" funnel and stuck the small end into 2' of clear plastic tubing-this makes adding hydro fluid in that rear port so much easier. Also some extra coolant, engine oil, etc.
A "carry all" costs only $100-$200 and allows you to haul all kinds of stuff at the 3ph. I also bought a 15 gal. electric sprayer for an ATV, which I bungee strap to the carry all when I need to spray Roundup. The sprayer was only $90 vs. one with its own frame and wheels for several hundred. This more than paid for the carry all.
It was 111 degrees F this week at my house. I brush hogged while wearing a vest into which go plastic packets of chemical which freezes at 65 degrees. They stay at 65 degrees for about 3 hours while body heat melts the chemicals from solid to liquid. They really suck the excess heat out of the torso and keep the chest area at a comfortable temperature (water ice would be too cold). I keep an extra set of packets in the freezer and swap them every 2 hours. It made driving the tractor in 111 degree heat totally bearable. Gatoraide helps too.
Ear protection, eye protection, dust mask, etc. as needed, depending on how you are using the tractor.
Electric air pump (or bike pump if on a budget). You aren't going to drive the tractor to the gas station when the tire needs a little air.
It helps to have an extra pin and clip or two. Check and see if there's a TSC store (Tractor Supply Company) near you. If so, go browse around. Tisco makes a top link that's shorter than the Kubota one. Occasionally that's needed on some 3ph implements.
About 2 years ago, the "Attachments" forum had a thread entitled something like "What attachment do you use least of all and wish you'd never bought?" I'd say 95% of the responses were PHD. The tractor type will not dig in true hardpan (skid steer with correct auger will). Downpressure units and augers with Pengo carbide tips and bits can help in hard soil. If you are digging holes for planting things, your backhoe is better suited anyway. If you are putting up fence posts for a living and have no bedrock or hardpan, then it might be worth buying. Mine just sits. I would suggest that you try using just the bh for a year or two and see if that meets your needs. If you still feel you really need it, you can always get it later. OTOH, if you buy it and don't use it, it can be difficult to recoup the investment (and it takes up space).
Good luck and have fun with that new toy, er...sorry....tool.
Tom_H is offline   Reply With Quote
Old 07-04-2009, 09:52 AM   #16 (permalink)
Super Star Member
Location: First organized permanent settlement in the northwest territory
This ============ or this is nice for fueling up the tractor .
__________________
Tractors
2003 Kubota BX1500/2004 Kubota Bx23/New- Kubota BX1500
60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
60'' MMM/Clamp on Forks/48'' MMM
South of Canton Ohio
L . B
LBrown59 is offline   Reply With Quote
Old 07-04-2009, 11:46 AM   #17 (permalink)
Deano's Avatar
Quote:
Wonder if you need a hazmat containment system??? The way our laws are, you might be illegal with all that fuel stored like that Lee...
__________________
Deano
2006 BX24, 5' New Implements rake, Wallenstein thumb, Bro-Tek rear skid plate, home made front skid plate, W.R. Long flat tooth bar, 4' finishing mower (TPH), box blade, post hole digger, New style seat!!!!! Country Manufacturing manure spreader, Agri-Fab drop spreader.
Deano is offline   Reply With Quote
Old 07-05-2009, 12:16 AM   #18 (permalink)
New Member
I read the same post about the PHDs Here is my situation. I am building a new house hence the purchase of the tractor. I am putting up a deck on the back and fencing in about 1 acre. So I am going to either need to rent one several days or buy one. I don't mind buying one if it will work... I have a lot of rocks as I am building on a hill. I have tried the one man auger's and found the pretty useless in our area. So what to do....
Old 07-05-2009, 12:48 AM   #19 (permalink)
Super Star Member
Quote:
Rent one for tractor.
__________________
Tractors
L . B
Old 07-10-2009, 10:41 PM   #20 (permalink)
New Member
RENT ONE>>> That defeats the purpose of buying one. If I spend $100 renting one and it works I could have applied that to a post hole digger and if it does not I have wasted a post hole digger... I bought one for $850 from the dealer I bought my tractor from. I also just ordered from brotek a front & rear skid, thumb, ripper, steering guard, tool box, & wheel spacers... What is next...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.31355 seconds with 9 queries
