Hi Izicc,
I just went through this last week on my BX22. Pulled it apart and turned out I had a cracked casting. When rdaustintx talks about the pivot I'm sure he is refering to the rotation point (where the drive gear case swivels on the bevel gear case) where the front wheels turn cw or cc as the steering wheel is turned. There is a 2 part seal there that can leak.
Getting it apart and back together was pretty easy. Kubota built a very service friendly machine. Clean it up BEFORE taking it apart to save yourself the pain of cleaning up bits of dirt from the inside of the cases. I think the only tools you need to get the whole job done is a 12,14,17mm wrench and a good pair of circlip removal pliers.
Drain the oil from the axle. Pull the tire off, and loosend the drive gear cover bolts (6 bolts, it's just easier when it is attached to the tractor). Then separate the drive/bevel gear case from the axle (4 bolts, don't damage the o-ring when you take it apart) and take the whole thing to a bench to work on.
Once on the bench, unbolt the drive gear case cover (6 bolts) and use the pry notches to get it off. There are two dowel pins so each side must come off evenly and be careful not to scratch the mating surfaces up. Then you have to cock the drive gear and gear case cover a bit to get the gear and cover to clear and come out (it's a puzzle of sorts). Set the drive gear and cover aside.
Look into the drive gear case. There is a circlip that holds the bevel gear case into the drive gear case. Don't worry about getting the circlip past the gear, just get it off the bottom of the bevel gear case. Then pull the bevel gear case out of the drive gear case.
Inspect the drive gear case just above center behind where the bevel gear case would be. That is where the most stress is on the casting and where mine cracked. It will look like just a hair line crack in the paint that follows the curve of the casting. If you think you see a crack, look on the inside of the drive gear case and see if the crack goes through (a mirror and flashlight help to get a good look).
If you see no evidence of a crack, just replace the seal ($20 for the seal. Both sides, one in the drive gear case the other on the bevel gear case are included) and see if that fixes it. Don't destroy the drive gear case seal too bad if possible because it is handy to use when tapping the bevel gear side of the seal onto the bevel gear case. And take note of how deep the drive gear case seal is driven into the casting.
There was a bit of metal in my gear cases probably due to the lack of fluid changes. If there are no big chunks, just clean it as best you can. Clean up the mating surfaces with some brake cleaner etc, apply liquid gasket to the drive gear case cover (note the groove on the drive gear case, this holds liquid gasket so it becomes an o-ring of sorts) and the drive gear case and reassemble. Then clean and apply grease to the bevel gear case o-ring and reassemble it too. Give it over night for the liquid gasket to cure then refill with oil.
If you want pictures of the crack or any other help, let me know.
Jeff
