ROPS bolt hole near hinge - bolt size?
   / ROPS bolt hole near hinge - bolt size? #11
the seat nuts is still a problem! I had to go the Home Cheapo last year to find the nut....I do not have my ROPS on but the seat is a PITA.
   / ROPS bolt hole near hinge - bolt size? #12
Pictures please!!:D:D
Deano
Ok, here are some pics :D
They are Hella oval 100 series work lights - part #: H15161011
They are 55 watt halogen clear lights. They really throw some light.
   / ROPS bolt hole near hinge - bolt size? #14
Once I put on the replacement Kubota seat, the nuts were just fine.. and no sliding off!
   / ROPS bolt hole near hinge - bolt size? #16
Nice setup! Are they switched separately or just hooked into the the lights circuit? I am actually planning to do the same for winter use since I usually don't get near the trees snow blowing. Easy spot to put on and then take off in the spring. At that height, they might make good ear warmers as well. ;-)
Dump Bed (A49251)
Dump Bed (A49251)
2019 Freightliner 122SD, Cummins X15 (A47371)
2019 Freightliner...
2004 FORD F550 SUPER DUTY FLATBED DUALLY TRUCK (A50046)
2004 FORD F550...
CLARK C40L FORKLIFT (A48992)
CLARK C40L...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A48837)
1 Bridgestone...
Air Compressor (A49251)
Air Compressor...
