10-30-2009, 08:43 PM
#11 (permalink)
| | Silver Member
| Re: BX air cleaner brkt. OK, here are the requested pictures of the bracket.
After further checking the invoice it appears to be:
KU K2561-98210 KIT BRAC $28.30.
Since I had just spent $4K+ at the dealer he threw in the bracket.
__________________ 2009 Kubota M7040, R1s, FEL, fork lift, 3 remote valves/levers, Gearmore Top-and-Tilt
2002 Kubota L48 Backhoe, 12", 18", 24" HD buckets
2001 Kubota BX2200, Turf, LA211 FEL
7.5' Hawse 3PT disc, 88" Gearmore 4G4 Industrial Box Scraper, 6' Alamo flail mower, 4' flail mower, 6' King Kutter rototiller, 4' rototiller, HD subsoiler, variety of A-frame mounted middle busters, ditchers, weeders, counterweights, (2) BushHog mowers 6', 4' |
10-31-2009, 12:31 AM
#12 (permalink)
| | Silver Member
| Re: BX air cleaner brkt. Definatly an up graded bracket. I will be looking into it as, I have already had my bracket break on my BX2660 when the hours were very low. They replaced with the same bracket as original- not impressed. Thanks for the information
__________________ Tim,
Kubota BX2660 |
11-03-2009, 10:09 AM
#13 (permalink)
| | Silver Member
| Re: BX air cleaner brkt. Just did a Google search using "Kubota K2561-98210" - the bracket kit. There were lots of hits and even several hits listed threads here on TBN from as far back as 2005. The information is out there and has been for some time.
Prices all seemed right at the $28 mark but then shipping has to be added. It might be cheaper to order one at a Kubota dealer if one is close by.
11-03-2009, 10:23 AM
#14 (permalink)
| | Veteran Member
| Re: BX air cleaner brkt. Odd, that new bracket looks exactly like the bracket that came OEM on my 2004 BX23.
I'm over 400 hrs on it, so far so good.....
__________________ BX23 w/60" MMM & thumb.
1966 Wheelhorse 856, Gear drive.
1966 Wheelhorse 876, HST drive.
w/50"sickle mower, 36" RDM, snow/grader plow, Alternator welder. |
11-04-2009, 12:39 AM
#15 (permalink)
| | Platinum Member
| Re: BX air cleaner brkt. Quote:
Originally Posted by Volfandt Odd, that new bracket looks exactly like the bracket that came OEM on my 2004 BX23.
I'm over 400 hrs on it, so far so good..... | Uh yeah, me too. Looks like the same bracket on my 05 BX23.
__________________ Bernie |
11-04-2009, 10:24 AM
#16 (permalink)
| | Silver Member
| Re: BX air cleaner brkt. It must be that the posters with bracket problems own pre-2004 BXs.
That brings up a question: How do the new brackets hold up? Volfant's bracket seems to be OK. Have any broken on BXs that are 2004+?
Those three cylinder engines sure vibrate at idle so even the new style bracket could recieve some metal fatigue damage.
I hate to increase the idle while cold so let it shake at startup. Not sure which would do the most damage - rattling itself to death or causing wear with high rpms at startup.
11-04-2009, 10:48 AM
#17 (permalink)
| | Platinum Member
| Re: BX air cleaner brkt. I figure that after about 15 seconds the oil is circulating and I idle it up just enough to smooth it out.
11-04-2009, 11:39 AM
#18 (permalink)
| | Gold Member
Originally Posted by Berniep I figure that after about 15 seconds the oil is circulating and I idle it up just enough to smooth it out. | My manual says to start at half throttle; only time it hits "idle" is when I shut it off. |
11-04-2009, 12:13 PM
#19 (permalink)
| | Veteran Member
Originally Posted by gwdixon Have any broken on BXs that are 2004+? | 2005 BX2230 with 285 hours and I haven't had any problems. Haven't looked under my hood in a while, but I THINK my bracket looks like the 'new' one pictured. Quote:
Originally Posted by TripleR My manual says to start at half throttle... | I admit I haven't pulled out my manual to check, but why would I start my tractor at 1/2 throttle? I liken that to starting my car and immediately, without delay, revving it to 3,000 RPM at the very time when friction is highest. Even if the manual says what you say it says, I'm starting my tractor at idle.
__________________ Kubota BX2230, FEL, Woods BH, 60" MMM, Bagger, 4' Box Blade, PHD, 8' x 20' 10k# Dovetail Trailer "Fate rarely calls upon us at a moment of our choosing." -Optimus Prime |
11-04-2009, 01:13 PM
#20 (permalink)
| | Gold Member
Originally Posted by KeithInSpace 2005 BX2230 with 285 hours and I haven't had any problems. Haven't looked under my hood in a while, but I THINK my bracket looks like the 'new' one pictured.
I admit I haven't pulled out my manual to check, but why would I start my tractor at 1/2 throttle? I liken that to starting my car and immediately, without delay, revving it to 3,000 RPM at the very time when friction is highest. Even if the manual says what you say it says, I'm starting my tractor at idle. | Didn't say you should, just what I do. Since Kubota designed it, I trust their knowledge and experience over mine or pretty much anyone else. I used the same procedure for my 03 BX2200 for six years and my son in law is doing the same thing. It runs like a top doesn't use oil and no repairs.
The last two new trucks I have bought start at a very high idle and then drop down.
I guess since we own our tractors, we can pretty much do what works for us. |
