idaguide
I plow about a 300 yard driveway with my B7800 and a rear blade. Because the driveway goes along the side of the hill, I plow towards the low side. However, with the plow on normally centered across the back, I'm only able to push the snow to the side, and it quickly builds up next to the road, forcing me to do what I call "the pushback" all the way down the driveway with my FEL. (It also goes down the hill.) This is very time consuming.
What I'm considering is adjusting the plow (sliding it) out to the right as far as it will go, so that the blade hangs out a couple feet over the edge, and hopefully will send the snow farther out, forcing the pushback less often.
What I'm wondering is whether or not this will be advantageous, or if the pressure of the snow on the rear blade will tend to jerk the front of the tractor around to the right, towards the downhill side. My rear tires are filled and chained, but I still think the whole thing will tend to rotate. I'm looking for advice because I don't want to find out that this doesn't work during the first big snowfall...it's a hassle to move the blade and I'd rather make up my mind ahead of time.
Any advice? Is my description clear?
Thanks in advance.
grae
Thanks in advance.
grae
