Hydraulic fluid in my engine oil...need ideas.
I have an ongoing problem with my B1750.
Hydraulic fluid from the hydrostatic trans is being pumped into the engine oil during operation.
I've had the dealer out twice to replace the seal on the hydraulic pump shaft as this appears to be the only point of separation between the hydraulics (3PL and power steering - no FEL) and the engine oil (the hydraulic pump bolts directly to the engine block).
Still the problem isn't fixed - after 4 hours operation the Hydro fluid is at the bottom of the dipstick and the engine oil is over-full by 1" on the dipstick.
My question - if there was a problem with the hydraulic pressure relief is it possible that high pressure in the hydraulics could go un-noticed and cause hydro fluid to be pushed through the hydraulic pump oil seal? - am I clutching at straws?
I'm at a loss... my dealer seams to think the seal is the only possible point of failure. The shaft that goes through the seal seems to have minimal wear and feels tight when being assembled. The tractor has done 1050 hours. The next step appears to be replace the entire pump and just hope that fixes it... $600+ is a lot when the diagnosis is to "hope" it fixes it.
Any Ideas?
Any Ideas?
