Results 1 to 8 of 8
  1. #1
    Member smbluthing's Avatar
    Join Date
    Oct 2008
    Posts
    30
    Crab Orchard Tennessee
    Kubota M6800HD
    Default 3 point cement mixer 80 hookup?
    I am almost a defeated man! I have a used mixer80 and finally got the hydraulic cylinder functioning. unless there is a way to extend the mixer on the 3 point hitch, it appears the pto shaft is too long. the Kubota is a M6800HD. just wondering if i am doing something wrong or do i need to somehow find a shorter pto shaft? thanks
  2. #2
    Advertiser
    Join Date
    Oct 2003
    Posts
    9
    Default Re: 3 point cement mixer 80 hookup?
    If your PTO shaft is too long.You can dammage your transmission case.Worst destroy it.
    You can shortin you shafts equal lengths.Place one shaft on your tractor and the other end on the implement. Let the shafts sit ON each other and check the differances and cut 1 inch shorter.You can use a hack saw or a cutting wheel. Good Luck
  3. #3
    Elite Member Baby Grand's Avatar
    Join Date
    Nov 2007
    Posts
    2,601
    Windsor, CT.
    L3240GST, B5100D & G5200H
    As Marshal noted:
    I did this with the "trilobulated" shafts (if you've seen one you know what I'm talking about) that came with my KKII tiller. Had a dickens of a time trying to get them back together - lots of deburring and cussing. Just mentioned it so you factor in some time for this important part of the job ...
    -Jim
    That's the problem with trouble.
    It always starts out as such fun."
    - Randall Brown
  4. #4
    Elite Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    4,105
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Quote Originally Posted by smbluthing View Post
    When I bought my MIXER80 years ago, I had to shorten the driveshaft also.
    It took a couple of tries, but it is easy to cut. Don't make it too short or
    it will come apart at full lift!
    FYI, I recently converted my mixer to hyd drive, so I got rid of the drive
    shaft.
    http://www.tractorbynet.com/forums/h...ete-mixer.html
    See my TBN projects at:
    http://mysite.verizon.net/resyfcgt/
  5. #5
    Join Date
    Oct 2008
    Posts
    30
    Kubota M6800HD
    before i mess up the cut...this is in a manual i found on an internet search...
    "Check the length of the PTO shaft, ensuring that it has a minimum axial play of
    (2 inches) in the shortest position (IT SHOULD UNDER NO CIRCUMSTANCES
    BIND). Check also the length of the PTO shaft at the point of full extension to
    ensure that the insert length between the two halves of the shaft
    is not less than (4inches)."
    do i still cut based on the 1" theory. thanks
  6. #6
    New Member ALF_HMC's Avatar
    Join Date
    Oct 2009
    Posts
    23
    Just south of Knoxville TN
    Montana 3440 HST
    I suggest you just give your mixer to a good freind at work and be done with it....
  7. #7
    Join Date
    Oct 2008
    Posts
    30
    Kubota M6800HD
    To my good friend at work...you may borrow anytime, realizing the fact that, the use a different PTO shaft after today might be involved.
    the shaft is at it's shortest point according to the owners manual.
    it looks like the 5" cut from both sides will make it just fit.
    i think an additional 2" from each side will give the 1.97" buffer.
    this will at full extension leave 5".
    the final cuts should be the same on the pto plastic shrouds?
    "measure 2 times cut one time" is a rule to reduce error. do all those that offer advise think i am on the right track? thanks smbluthing
  8. #8
    Join Date
    Oct 2009
    Posts
    23
    Montana 3440 HST
    One thing about it. The shafts are a replaceable Item if you do happen to make a mistake! Good luck... I'll talk to you at work.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
