11-03-2009, 11:56 PM
#1 (permalink)
| | Member
| M59 Tires - Foam Filled? Hi guys,
Got a quote today for filing the rear R4s on the M59 with foam...$1100 for the pair and they claim it will add about 1350lbs. to the rear.
What are ya'll paying for foam filling and how much weight does it add? Are these prices typical?
Thanks,
Mark
__________________ 2009 Kubota M59, Hydraulic Thumb, front and rear aux, little orange toolbox.
8' Ford 917 Flail Mower - not running yet Other Toys
Huskee (Speeco) 35 ton log splitter
Dolmar PS-5100s
Stihl MS-441
Makita DCS-6401..upgraded to 79cc
Polaris Sportsman 850XP EPS
Polar Trailer 1500 HD Tandem (LOVE this little trailer)
1 Catahoula Bulldog and a pit bull or two |
11-04-2009, 09:40 AM
#2 (permalink)
| | Elite Member
Join Date: Apr 2000 Location: Cedartown, Ga and N. Ga mountains
| Re: M59 Tires - Foam Filled? Mark that sounds about right. Foam filled a Bobcat skid steer and it was $1k for the four tires. Another thing to look at is the type of foam. Some cure very ridged and make for a rough ride while other types are more flexible. Expect the ride to be rougher with either type of foam.
MarkV |
11-04-2009, 10:24 AM
#3 (permalink)
| | Veteran Member
| Re: M59 Tires - Foam Filled? Check with your Kubota dealer before getting this done.
Operation of a backhoe involves frequently picking up the rear end of the machine by downpressure with the hoe and moving it side to side by swinging the boom, or "crawling" by pulling yourself along with the hoe. An extra 1350 lbs might not allow this.
I know my JD dealer strongly discouraged filling my rear tires...
__________________ 40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
Isaac Asimov |
11-04-2009, 11:30 AM
#4 (permalink)
| | Veteran Member
Join Date: Aug 2006 Location: Boston & Martha's Vineyard, People's Republik of Massachusetts
| Re: M59 Tires - Foam Filled? have foam filled all 4 tires on my m59. Love it. Probably added 2k in weight, which would affect towing, but I don't tow. Around a buck a pound seems the going rate - that seems reasonable.
CurlyDave - M59 has a crawl control, so no need to do it with the hoe. I think the hoe can still lift the rear end, but honestly it doesn't come up for me, so I can't remember. The rear throttle/directional control makes a big difference in how one moves it.
__________________ ----------------------------------------
Charles
Kubota B3030
Kubota M59 w/hydro thumb
Neat stuff - ATI Preseeder, Hydraulic PHD, Wallenstein BX62r Chipper, Millonzi Grapple, CA 4n1 Bucket. Delta Hook Rear QA system.
Too many other random attachments to list (or to own, per my gf) and a really bad tool addiction. But at least I haven't bought a dump truck or bulldozer. Yet. |
11-04-2009, 11:59 AM
#5 (permalink)
| | Veteran Member
| Re: M59 Tires - Foam Filled? My JD 110 TLB also has a creeper -- there is a difference between using that function and using the hoe to reposition, often a very significant difference.
Just as one simple example, I do not see how it would be possible to cross a trench if I could not pick up the rear end with the hoe and push the machine forward...
Isaac Asimov |
11-04-2009, 05:47 PM
#6 (permalink)
| | Elite Member
| Re: M59 Tires - Foam Filled? Quote:
Originally Posted by CurlyDave My JD 110 TLB also has a creeper -- there is a difference between using that function and using the hoe to reposition, often a very significant difference. | Dave I agree that there is a difference. Often I move my tractors around with the backhoe. I know that Kubota does not recommend loading the tires on their cab and commercial TLB models. I have always considered it a liability issue due to the extra weight in a rollover. There is a higher center of gravity on both types of tractor.
You do make a point I have never considered though. The added weight does limit the stabilizers lift capacity and the ability of the hoe to move the extra weight. Personally I find loaded tires to be such an improvement in stability and traction I still have to go that way.
MarkV |
11-04-2009, 10:15 PM
#7 (permalink)
| | Veteran Member
| Re: M59 Tires - Foam Filled? I have to admit I'm curious now, I'll mess around next time the hoe is on, I'm still in 3pt time. I've always crossed ditches by just driving over them, why would you do otherwise? Genuinely curious, may just be an aspect of my usage so it hasn't come up for me.
Charles
Kubota B3030
11-04-2009, 10:26 PM
#8 (permalink)
| | Veteran Member
Originally Posted by Charlesaf3 I've always crossed ditches by just driving over them, why would you do otherwise?. | Think more along the lines of a trench.
__________________ "If everyone is thinking alike, someone isn't thinking." George Patton |
11-04-2009, 11:44 PM
#9 (permalink)
| | Platinum Member
Join Date: Jun 2005 Location: Southern NH & Central NH (God's Country)
Originally Posted by CurlyDave Check with your Kubota dealer before getting this done.
I know my JD dealer strongly discouraged filling my rear tires... | Kubota M59 is a very light but strong machine for its size. I have my operating weight of my L39 at 8,100 to 8,300 Lbs depending on whats on the QA.
Foam them, There should be no concern lifting an moving side to side if it is only 1,350 lbs more with the bigger M59.
If my L39 was bothered by the extra 850 Lbs over the rear, I'd not have been able to extricate the machine out of sme really hairy situations or hop trenches, etc. |
11-05-2009, 12:44 AM
#10 (permalink)
| | Member
| Re: M59 Tires - Foam Filled? Thanks for all the info guys. I never thougtht about what CurlyDave mentioned. The Kubota manual says to add CC to the tires if no backhoe is installed, and that it is not necessary with the backhoe. If you frequently remove it, as do I, I would like to have the extra weight for loader work.
Is CC the same weight as foam?
I wonder what Kubota has to say about CC and the backhoe?
-Mark
Dolmar PS-5100s
Stihl MS-441
