HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Kubota > Kubota Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-07-2009, 02:07 PM   #11 (permalink)
Default Re: l2800 want crank.....
Ok here is what I found. I was able to jump the starter from one post to the other and spin it. It appeares tht the bendix is not engaging. crawled up under the tractor and on the right side of the trannie there are 2 sensors screwed into the trannie . One of them was unplugged.
1st what is this sensor?
2nd how many volts should I see from the little wire that plugs into the starter when I turn the switch to crank. this is the wire that should be engaging the nendix correct? How many volts to engage?
Thanks
Wade
blackrat is offline   Reply With Quote
Old 11-07-2009, 03:01 PM   #12 (permalink)
radioman's Avatar
Without a WSM, and just to guess, its probably one of the saftey switches. Do you see where the other end should go? Have you plugged it in and try again? As for the starter, it spins but the solenoid doesnt come out to turn the engine ?
Not sure what you mean by nendix ?
radioman is online now   Reply With Quote
Old 11-07-2009, 03:05 PM   #13 (permalink)
ibnxe's Avatar
Don't know the anaswer to the question about the sensor on the transmission.
The heavy wire to the starter, comes directly from the battery. The smaller wire comes from the start switch. When the ignition switch is in the start position, battery voltage should be present at this wire. The small wire energizes the solinoid, that in turn, draws the bendix into the flywheel, and at the same time, closes the contacts that connect the battery to the starter windings.
Battery voltage can be anywhere from about 12 volts even to 13.5 volts, depending on when the battery was last charged. Durring cranking, the voltage can fall as low as 9.5 volts, but should recover to near 12 volts as soon as the cranking stops.
__________________
Kubota BX23
Wallenstein BX42 Chipper
Rankin 48" Box Blade
ibnxe is offline   Reply With Quote
Old 11-07-2009, 03:15 PM   #14 (permalink)
Super Star Member
Egon's Avatar
Starter motor - Wikipedia, the free encyclopedia
Will this help.
__________________
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
Egon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.17839 seconds with 8 queries
