SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,524
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
My BX1500 has a serious problem. Everything on the tractor is working perfectly except the transmission. Im running SUDT and the level is right - fluid clear and clean. Never a problem until yesterday when I noticed that pushing the go pedal for reverse in hi range caused the tractor to shudder. Forward fine - lo range fine both directions. Went ahead and got a good start on snowthrowing. Finished today and its getting worse. You have to really nurse the go pedal to get it to climb a hill or push - even in lo range. Once the tractor encounters a bit of real resistance the go pedal will just drop to the floor as if it lost its servo connection to the transmission and the tractor loses all thrust - it seems to be out of gear. If you let up and re press the pedal it has firmed back up and if you nurse it by pushing gently you may be able get enuf thrust to crawl out of the situation. Reverse is worse - the tractor wont back up much of an incline.
Does anybody know where to look for this problem? Iv heard of something called the charge pump that I think is necessary to supply the servo link to the variable volume hydrostatic pump. Is that correct? Why would it suddenly take a walk?
Ill get to looking for the obvious in a few minutes when the caked snow melts off. Boy I hope this is accessible from external.
Thanks,
larry
Thanks,
larry
