Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Mar 2010
    Posts
    3
    Default BX23 Bent loader Bucket Howto Fix???
    I wasn't payin enough attention and bent the lower edge of the loader bucket down about 1.5" in the center, can't seem to get it back to straight. Any suggestions??
  2. #2
    Gold Member
    Join Date
    Dec 2008
    Posts
    252
    Central Vermont
    2008 Kubota BX2660
    Default Re: BX23 Bent loader Bucket Howto Fix???
    Take the bucket off, turn upside down, block under each end and swing the 12 pound sledgehammer.
  3. #3
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,381
    NW Oregon
    Deere 317 & L118
    Quote Originally Posted by Usta View Post
    exactly.
    My Fleet:
    2004 Deere 317 Skid Steer Loader
    66" Construction bucket, imatch QA adapter, Bobcat landplane ,4 in 1 bucket, Pallet forks
    2005 John Deere L118
    42" deck, bagger
  4. #4
    Join Date
    Jul 2006
    Posts
    194
    Falling Waters,WV
    Kubota BX2200
    Wear ear protection.....That's a big drum!
  5. #5
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    limerick pa lycoming county pa
    kubota bx23
    Put a 2x4 on edge and place bucket edge on it and lift tractor up and see if it moves ( I don't think it will but its worth the try).
    Put apiece of angle on the top back of the bucket take a decent pipe clamp from there to the center of the cutting edge and crank her up.
    Over bend it a little because it will spring back.
    tom
    If it ain't broke we will help you brake it
    If it is broke we will help you get it fixed!
    https://www.facebook.com/joseph.t.mussington
  6. #6
    Veteran Member npalen's Avatar
    Join Date
    Nov 2009
    Posts
    1,596
    Beloit, KS
    Kubota B9200 HSTD and Mahindra 3015
    Load the bucket with heavy material then carefully lower the bucket on the 2x4 mentioned above?
  7. #7
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    The BX is too light to use its own weight to bend the bucket back. Even with extra weight in the bucket. Either use a hammer or heat torch
  8. #8
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,701
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Quote Originally Posted by fierbyrd View Post
    I use a hyd jack, chains, and an I-beam. A wooden beam would work, too.
    I have also tried adding heat with an OA torch with rosebud tip.
    One trick that I learned straightening motorcycle frames is to apply some
    bending force, then whack it with a sledgehammer to get the bend to
    set, rather than just springing back.
    Attached Thumbnails Attached Thumbnails BX23 Bent loader Bucket Howto Fix???-l_4n1_bending-jpg
  9. #9
    Silver Member RoyBrooks's Avatar
    Join Date
    Sep 2003
    Posts
    125
    Ontario, Canada
    Kubota/B7500,4WD,Hst
    I straightened mine using the hydraulic jack chain and 6 by 6 wood beam took a few tries but is much better now. Still have about a 1/2 " drop in the center of the bucket but can live with that for now. The other option would be to cut off the cutting edge and replace it .
  10. #10
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,668
    central Wisconsin
    Kubota B7800, B26 TLB
    Fierbyrd, Just what were you doing that caused the bucket to bend? A BX23 is not that heavy a tractor, was speed involved?
Similar Threads
  1. Replies: 14
    Last Post: 09-11-2013, 09:40 PM
  2. BX23 Loader
    By BimmerRacer in forum Kubota Owning/Operating
    Last Post: 06-13-2009, 11:11 AM
  3. Droopy bucket fix
    By alchemysa in forum Kubota Owning/Operating
    Last Post: 11-29-2006, 09:37 AM
  4. Tractor Sizing BX23 FEL bucket size too small?
    By ESM in forum Kubota Buying/Pricing
    Last Post: 04-03-2005, 10:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
