Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Mar 2010
    Posts
    1
    Default Bx7800 Safety Switches
    My 3 year old b7800 won't start after mowing high brush. I was able to jump it at the starter to get it in the barn so I believe one of the safety switches is not engaged. Any recommendations or references where I can get a interlocking switch diagram? Thanks in advance.
  2. #2
    art
    art is offline
    Super Member
    Join Date
    Apr 2000
    Posts
    5,849
    central New York
    all makes and models
    Default Re: Bx7800 Safety Switches
    I'd start with the pto switch.
  3. #3
    Veteran Member crbr's Avatar
    Join Date
    Apr 2007
    Posts
    1,667
    East TN
    Kub - 2K6, B7800
    Quote Originally Posted by tythreatt View Post
    One suggestion from experience:
    Hydrostatic pedal. It has a safety switch and can lose it's neutral safety position easily. Rock the pedal and allow it to find it's position for starting. I have had to even use my hand for sensitive movements. Patience. It can be finicky.
    ** Kubota **
    Psalms 86
    John 1:12-13
    Duraflap / Kaydenco not worth a hoot for service or products.
    "Google" is a proper noun, not a verb.
    If you mean what you say, then say what you mean, or just don't say anything
  4. #4
    Elite Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    4,784
    Somerset, Ky
    currently own F3080 F3080 B2620 FEL/BH RTV1140
    Quote Originally Posted by crbr View Post
    This is a common problem with the B7800. If yours quits and you hit it on the hood and then get back on it or was on it and leaned forward and hit the hood and slightly accidently moved the foot pedal you would then post on TBN that if your B7800 dies and won't start or sits and won't start that hitting it on the hood fixes it. Your convinced and will go to your grave believing the whack on the hood fixed it, no doubt about it and no one will ever talk you out of it. That was me, only I pulled apart all of the safety plugs under the seat instead of hitting it on the hood, until one day I moved the foot pedal and it started and from then on when it wouldn't start (the B7800) I would rock the foot pedal until it started. If it's a B7800 always rock the foot pedal, if that doesn't do it, then start unplugging and replugging all the safety switches. If those don't fix it, hit it on the hood.
    2012 B2620 FEL BH, 2010 F3080 4WD 72" Rear Discharge Deck, 2012 F3080 4WD 72" side discharge deck, 2010/2009 RTV1140CPX , RatchetRake, Forks, ...DEARBORN 2 BOTTOM PLOW 12" ?? FOR SALE $425).... Drawbar and Horse Drawn disk 11 Dodge Ram1500, 13 Ford Flex. 2009 Subaru Impreza Sport
Similar Threads
  1. Rotary Cutter Bush Hog Safety Guards
    By wolfweb in forum Attachments
    Last Post: 12-06-2009, 09:57 AM
  2. PTO Shaft Safety Shield.....
    By foggy1111 in forum Attachments
    Last Post: 09-16-2009, 06:32 PM
  3. JD LT150 Safety Switch Problem
    By Skidmark25 in forum John Deere Lawn & Garden
    Last Post: 04-26-2009, 08:42 PM
  4. 3pt hitch = safety feature / revisited
    By Soundguy in forum Safety
    Last Post: 12-05-2005, 04:21 PM
  5. Farm Safety Week
    By JazzDad in forum Safety
    Last Post: 09-02-2005, 09:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
