Page 22 of 48 FirstFirst ... 121920212223242532 ... LastLast
Results 211 to 220 of 473
  1. #211
    Platinum Member kw22614's Avatar
    Join Date
    Dec 2012
    Posts
    548
    Manassas, VA
    Kubota BX1860
    Default Re: Do your own Fluids and Filters on a BX
    Oil change/filter replace done. 50 hr service complete!
  2. #212
    Gold Member CanuckPT's Avatar
    Join Date
    Sep 2012
    Posts
    414
    West Chesterfield, NH
    2011 Kubota B3300SU
    Default
    It's a great feeling isn't it! Well done!!
    Sent from my iPhone using TractorByNet
    Kubota BH77 Backhoe with Bro-Tek mechanical thumb & Bro-Tek Ripper Tooth; Loflin 48 inch forks; Bro-Tek 2" rear wheel spacers; StabilWorks custom stabilizers; EA 66" Box Blade; WoodMaxx WM-8H Chipper; NorTrac Quick Hitch; Small Wood Lot Tools 3 PH Log Skidder Attachment
  3. #213
    Super Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    7,180
    Somerset, Ky
    L3901HST F3080 RTV1140 BX2370-1
    I always feel a sense of satisfaction after completing the regular scheduled maintenance and don't think I'd feel as good if I had the dealer do it and for certain wouldn't after paying the bill.
    I have several fuel filters because I've never changed one and I just clean the air filters with compressed air. Course up to this point I've never owned a high hours kubota out of 17 purchases;. One of them (F2680) was used that I bought last month and just did the 150 hours service on it last week. I had also done the 50 and 100 hours service on the used F2680 bought last week since I was the original owner of it for 4 years,
    2017 L3901 HST FEL, 2017 BX2370-1, 2012 F3080 4WD 72" RD, 2010/2009 RTV1140CPX , 72" Woods RFM, 60" LP Grapple, J DUNN Tree Grapple, 6' LP Rotary Mower, LP25 Hydraulic PHD, LP Quick hitch, RatchetRake , Rip and Dig, LP BB, LP 50" Tiller, Snow plow, Titan SSQA Forks, Titan Hitch Mounted Ripper, Titan SSQA to 3PH adapter plate, Sickle mower .. and Horse Drawn disk 13 Toyota Tacoma Double Cab, 18 Ford Flex
  4. #214
    Join Date
    Oct 2013
    Posts
    589
    Maine
    Kubota B2650HST. Kubota Z125S
    I had the dealer come to my house to do the 50 hour service because the tractor was new and under warranty. The mechanic showed me how to do it. I just wanted to have a maintenance record for the critical 50 hour service so there would be no issues if the tractor broke early in its life. Now I do all the fluid and filter changes myself-- pretty easy job.
  5. #215
    Join Date
    Apr 2008
    Posts
    7,180
    Somerset, Ky
    Recently did F3080 100 hour 3 year oil, oil filter, hyd filter and antifreeze change for sold F3080.
    Nearing 50 hour service to do on B2620, F3080 and 100 hours on RTV1140 but maybe they'll make it to spring or some of them will. My brother in law has a direct injection heater for his machine shop so I give him all removed hyd and oil so he'll want me to do them before spring. No, none of the hyd fluid will be exchanged before or at the 50 or 100 hours interval by me. I follow the kubota owners manual recommended change intervals and feel good doing so.
  6. #216
    Join Date
    Oct 2010
    Posts
    537
    NYS--Various Parts
    Kubota B3000HSDCC, BH77, 5' Belly Mower, 6' Hyd. Angle Plow
    Way to stay on top of things, John.
  7. #217
    Join Date
    Apr 2008
    Posts
    7,180
    Somerset, Ky
    Oops!!! Also need to do some greasing.
  8. #218
    Join Date
    Dec 2012
    Posts
    548
    Manassas, VA
    Kubota BX1860
    Yes! Greasing is important. Forgot to mention I had greased my pedal assembly and all fittings on fel when I did my service last Sunday. Didn't look like it needed it but I try to put a couple pumps of fresh grease in everything about every 10th or 12th use (no matter how many or few hrs logged). Cheap insurance not to have major headaches.
  9. #219
    Gold Member
    Join Date
    Jun 2013
    Posts
    434
    GIg Harbor ish
    .l5460, bcs 725, 852
    Quote Originally Posted by HillStreet View Post
    My dealer wanted $650 to come out and do 50 hr service. So I passed.
    I had lug nuts very loose so be sure and check yours. I should have checked mine at the 5 hr mark probably.....
    Plus I happened to notice about a third of the rear wheel bolts were not seated correctly by the dealer. Easy fix but just more setup stuff that's needed attention. Here's one.
    Do your own Fluids and Filters on a BX-wp_20131028_008-jpg
  10. #220
    Join Date
    Apr 2008
    Posts
    7,180
    Somerset, Ky
    Quote Originally Posted by BGigHarbor View Post
    Another reason to do your own service and check your own machine. There are some dealers with great service depts. but no one cares as much as you do or you should for YOUR machine.
Similar Threads
  1. Surprises when picking up fluids / filters for 50 hr service
    By canoetrpr in forum Kubota Owning/Operating
    Last Post: 08-01-2007, 06:40 PM
  2. Brand Name Fluids and Filters
    By 40_acre_mule in forum Kubota Owning/Operating
    Last Post: 10-14-2005, 02:51 PM
  3. near 50 hrs.?'s about oil, fluids, filters on DK45
    By GeorgeW in forum Kioti Owning/Operating
    Last Post: 04-24-2005, 12:09 PM
  4. YM200 fluids and filters? What do I need.
    By callais in forum Yanmar
    Last Post: 03-21-2005, 03:48 PM
  5. 50 hour service - Cost of fluids and filters?
    By SacandagaBrad in forum New Holland Owning/Operating
    Last Post: 02-07-2004, 10:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
