3v0
I do not know... But I expect the size of the shop vac does not much matter because the main diff between them is how much air they move rather then the vacuum that they will pull.
No need to use shop vac if your dumping fluid on purpose.
Did my 50hr service a little while back on my BX2370. When I pulled the strainer I had #5 stopper ready to put in. Big problem...the #5 stopper was way too small. Put the strainer back in and tried the shop vac. It sucked....in a bad way. Sure there was no fluid leaking out, but the vac was sucking the fluid out. Took my stopper and wrapped it with rubber tape and was able to make it work. All in all I lost about a gallon of fluid. I need to find another stopper that is bigger for the next time.
Where are you experienced vacuum users?
