Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Elite Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    4,793
    Somerset, Ky
    currently own F3080 F3080 B2620 FEL/BH RTV1140
    Default RatchetRake for Brush Clearing
    I have said before that I've used my RR for finish leveling and not for brush clearing. Well, I have a new story. I have a pile of topsoil fermenting in storage on the lower part of my property. Now thta I'm doing a garden, I need the topsoil topside. The briars, brush and water sprout trees have done great in the topsoil pile.
    I tackled them today with my new RR on my BX2660. Some of the trees were 8' to 10' tall and deep into briars, some rocks and other under brush. I used the front long teeth of the RR in forward and the stuff just started falling, not the trees. I stuck teeth under the water sprout trees and just lifted them up and drug them out. I went forward with big front trees and back drug with big teeth some and lower teeth some to pull almost everything up. Ground is a bit moist so bad traction for tractor but easier pulling the stuff up. Here's a pile of what I pulled up that I just lowered teeth and went forward after back dragging it away from the working pile and it rounded it all up and pushed it into a pile. Had to leave but in 30 minutes it changed from a wall of brush 10' to 15' high to this so I can now see what's actualy there.RatchetRake for Brush Clearing-img_0348.jpg
    Attached Thumbnails Attached Thumbnails RatchetRake for Brush Clearing-img_0350.jpg
    2012 B2620 FEL BH, 2010 F3080 4WD 72" Rear Discharge Deck, 2012 F3080 4WD 72" side discharge deck, 2010/2009 RTV1140CPX , RatchetRake, Forks, ...DEARBORN 2 BOTTOM PLOW 12" ?? FOR SALE $425).... Drawbar and Horse Drawn disk 11 Dodge Ram1500, 13 Ford Flex. 2009 Subaru Impreza Sport
  2. #2
    Join Date
    Apr 2008
    Posts
    4,793
    Somerset, Ky
    Default Re: RatchetRake for Brush Clearing
    Pictures messed up. Here's the rest of them.
    Attached Thumbnails Attached Thumbnails RatchetRake for Brush Clearing-img_0352.jpg   RatchetRake for Brush Clearing-img_0353.jpg   RatchetRake for Brush Clearing-img_0354.jpg   RatchetRake for Brush Clearing-img_0355.jpg   RatchetRake for Brush Clearing-img_0356.jpg
    RatchetRake for Brush Clearing-p1060523.jpg   RatchetRake for Brush Clearing-p1060524.jpg   RatchetRake for Brush Clearing-p1060527.jpg
  3. #3
    Join Date
    Mar 2007
    Posts
    211
    ok jt, i'll bite.
    what's the extra board w/the uprights doing in the front end loader bucket?
    shrekbelly
  4. #4
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,665
    central Wisconsin
    Kubota B7800
    Quote Originally Posted by shrekbelly View Post
    ok jt, i'll bite.
    shrekbelly
    I'll guess it is the packing cause he took pics when he got it.
  5. #5
    Join Date
    Apr 2008
    Posts
    4,793
    Somerset, Ky
    ok jt, i'll bite.
    shrekbelly
    It's the new light weight magic bucket balance level motivation indicator. Or better known as the piece of wood with the triangles that the RR was taped to for shipping. Guess it kept it level in the UPS truck.
  6. #6
    Join Date
    Mar 2007
    Posts
    211
    thanks, jt
    i knew an answer was forth coming.
    shrekbelly
  7. #7
    Veteran Member Ken45101's Avatar
    Join Date
    Feb 2009
    Posts
    2,475
    southern Ohio
    Kubota M5040, M9540, B21 TLB, B2710, RTV900, JD 325 Skid steer, KX-121-3 mini excavator
    Wow, that thing sure looks well built! You picture looks better than what they have on their website.
    I just wish they made them a bit bigger for what I need and, of course, wish they were still available direct
    Ken
  8. #8
    Join Date
    Apr 2008
    Posts
    4,793
    Somerset, Ky
    Quote Originally Posted by Ken45101 View Post
    Ken
    Bigger in what way?
  9. #9
    Join Date
    Feb 2009
    Posts
    2,475
    southern Ohio
    Quote Originally Posted by JOHNTHOMAS View Post
    Bigger in what way?
    For wider buckets and higher hp ratings. I have a 78" bucket on my skid steer and it's 80 hp.
    Ken
  10. #10
    Veteran Member Deano's Avatar
    Join Date
    Oct 2008
    Posts
    1,035
    Southern Maryland
    Kubota BX24
    Yellow???!!!! You need to fix that! Tractor Supply, New Kubota Orange!!
    Deano
    Deano
    2006 BX24, 6' New Implements rake, Woods RB60 rear blade, Wallenstein thumb, Bro-Tek rear skid plate, home made front skid plate, W.R. Long flat tooth bar, 4' finishing mower (TPH), 4' box blade, post hole digger, New style seat!!!!! Country Manufacturing manure spreader, Agri-Fab drop spreader.
Similar Threads
  1. Miss my RatchetRake
    By JOHNTHOMAS in forum Kubota Owning/Operating
    Last Post: 09-07-2012, 06:40 AM
  2. Rotary Cutter 60" or 72" Bush Hog for brush clearing with 40hp
    By IslandTractor in forum Attachments
    Last Post: 11-03-2011, 11:00 AM
  3. Cost of clearing a path?
    By Blackhammer in forum Land Clearing
    Last Post: 07-05-2009, 08:04 AM
  4. Clearing 80 acres with a Mastacator
    By monkeymonk in forum Projects
    Last Post: 09-06-2006, 01:05 PM
  5. Clearing progress, brush is evil
    By Highbeam in forum Photos
    Last Post: 05-04-2005, 11:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
