dcyrilc
Super Member
Boy - I'm surprised at all the dithering on these replies. Back blading with a front end loader is a standard operating procedure. I appreciate the tips on technique, but for those worrying about breaking your tractor leave it go. If you break it, fix it. Or maybe it means you under-bought originally and need to get a bigger one anyway. If your tractor can't take a little abuse you better look at a different brand.
Mf
Even our Deere 544G loaders at work have warnings in the manual about using the bucket at excessive angles. This is a $80K, 24K# machine which will lift 24.5K#. For many machines, most of the damage will begin showing in the bearings and pins through excessive wear and slop in short order.
