M7040 and pulling a subsoiler?
   / M7040 and pulling a subsoiler? #1
tom4018
South Central Ky
Kubota M7040HD
Would a M7040 pull a 2 shank subsoiler or should I stick with a one shank? Looking at a couple old Ford subsoilers and wondered if sticking with one shank would be better.
   / M7040 and pulling a subsoiler? #2
It all depends on your soil type and how deep you going. 24" in heavy clay would make one hard to pull, but sandy soil would be a lot easier. It is usually only the heavier soils that benefit from subsoiling so if that is what you have then start with one and see how it goes. Good luck.
Some 30 years ago a farmer friend who was also a darn good engineer/machinist designed and built a two shank subsoiler with hydraulic trip resets from a JD plow. It was designed to trip and automatically reset when hitting rocks in the ground. He pulled it with a 2WD JD4020. He demonstrated it in the area to see if there was any interest in the hopes of building and selling them. It was a good idea, but nobody bought one so the prototype was the only one he made. The 94hp 4020 handled the two shanks OK in medium heavy ground.
   / M7040 and pulling a subsoiler? #3
I've only used a single shank in clay soil. It worked well.
A two shank should be just fine but as Toolguy mentioned, it depends on the soil. Exposed bedrock would make for tough going.
   / M7040 and pulling a subsoiler? #4
Worse than clay is hardpan. Two things can help. Make the top link as short as possible to get a better bite. Use ballast on the subsoiler:
   / M7040 and pulling a subsoiler? #5
Here's what vintners around here use for "subsoiling" when planting new vineyards:
  • Picture 36.pdf
  • Picture 32.pdf
  • Picture 31.pdf
  • Picture 30.pdf
   / M7040 and pulling a subsoiler? #7
I'd be making the top link longer to hold the point under and you won't need the weight!
   / M7040 and pulling a subsoiler? #8
No, it works the other way around. Shortening the top link makes a greater angle, which actually bites in better. I was doing it with the link long, like you said, and that wasn't working. Several TBNers told me to shorten the link instead for it to work. They were correct: when I shortened the link, it worked.
1997 HUBBLER BROS. LOGGING TRAILER (A50854)
1997 HUBBLER BROS...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
1271 (A50490)
1271 (A50490)
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
CM Trucks Utility Bed (A49461)
CM Trucks Utility...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
