Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Member
    Join Date
    Mar 2010
    Posts
    30
    BX2360
    Default bx tubes
    i guess, i''ll have to go the tube route for one or both of my fronts on my bx2360.
    since i admit to being an idiot, can anyone advise me on a tube size or are the tire dimensions enough, for the boys at the local sears tire or walmart center?
    regards, D902 BX PILOT
  2. #2
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,752
    Northern, IL
    Branson 2400H, JD X540
    Default Re: bx tubes
    Quote Originally Posted by D902 BX PILOT View Post
    Tire size is all you should need. Not sure on this size of tire but they may have tubes with different valve stem styles and locations. Make sure you get ones that will work with your rims.
    Roy
  3. #3
    New Member
    Join Date
    Oct 2004
    Posts
    14
    Manheim PA
    Kubota BX24
    not sure of your tire size but my BX24 has a 18x8.50-10 size tire which is just about impossible to find a tube for, tire shop sold me tubes that are sized 18x8.50-9.50 as a alternate size which did fit ok
    2008 BX 24 FEL, BH, PHD, 60" MMM, Toothbar
  4. #4
    Join Date
    Aug 2008
    Posts
    1,003
    Forget the tubes, been there before and done that, get slime and call it a day...
  5. #5
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    oh man ! yesterday when I needed the bota to move 89 bundles of shingles from trailer to garage, the front right tire was flat. I put air in it and dunked it in my pool. I found the bead on the back side is leaking a tiny bit. Not sure if I am gonna get tubes or try bead sealant. any ideas anyone ?
  6. #6
    Elite Member oldballs's Avatar
    Join Date
    Dec 2009
    Posts
    2,913
    Kansas...USA
    Kubota B2620 , Case 448 Kubota B2650
    I had a can of bead sealant from several years ago. It was still good . For some reason, that company doesn't make it anymore. I broke the bead on both sides, tried to smooth the rim surfaces with medium emery paper, brushed the sealant into the rim and the tire bead. It's been holding air for a month now without any loss. Hope this helps.
    Kubota B2620 HST (2012) Case 448(1983)
  7. #7
    Super Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    7,136
    Somerset, Ky
    L3901HST F3080 RTV1140 BX2370-1
    Quote Originally Posted by oldballs View Post
    Quit telling about bead sealant....unless your going to share with us.
    Thought you were going to find us a place to get it. Take your can to a Lab or something and have them make us some.
    2017 L3901 HST FEL, 2017 BX2370-1, 2012 F3080 4WD 72" RD, 2010/2009 RTV1140CPX , 72" Woods RFM, 60" LP Grapple, J DUNN Tree Grapple, 6' LP Rotary Mower, LP25 Hydraulic PHD, LP Quick hitch, RatchetRake , Rip and Dig, LP BB, LP 50" Tiller, Snow plow, Titan SSQA Forks, Titan Hitch Mounted Ripper, Titan SSQA to 3PH adapter plate, Sickle mower .. and Horse Drawn disk 13 Toyota Tacoma Double Cab, 17 Cadillac XT5. 2007 Toyota FJ Cruiser
  8. #8
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,112
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Quote Originally Posted by radioman View Post
    [Assuming no rim damage] Bead leaks are sometimes due to the tire bead moving very slightly from its longtime position on the rim during hard use. This is usually because the inflation was not adequate for that use. These can sometimes be made to reseal. Deflate your tire and wash [or pressure wash lightly] the seated bead area. Then reinflate to max pressure and immediately use the tire for a high load chore for a while. Often the bead will reseat air tite. Stay at max pressure for a few days before lowering the pressure to your preferred inflation.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  9. #9
    Join Date
    Dec 2009
    Posts
    2,913
    Kansas...USA
    In keeping with the spirit of TBN, I promise to get on it. But without a digital camera, you'll have to imagine what a can of it looks like.
  10. #10
    Join Date
    Apr 2008
    Posts
    7,136
    Somerset, Ky
    Rim & Bead Sealer, Flat Tire Prevention, Tires & Supplies
    BlackJack Tire Repair | Bead Sealer (Flammable) 32oz can
    Do these appear to be or do the bead seal?
    $20 on Ebay including shipping. Search Bead sealer on Ebay.
    Another edit. $6.99 Advance Auto Parts
    http://shop.advanceautoparts.com/web...91_A%7CGRP2068
Similar Threads
  1. Price Check BX 24 and BX 25 Pricing
    By Eightpoint in forum Kubota Buying/Pricing
    Last Post: 02-22-2014, 12:50 AM
  2. Attention B3030 owners & BX
    By gdh in forum Kubota Buying/Pricing
    Last Post: 03-19-2010, 04:00 PM
  3. Is a BX tractor right for me?
    By JDKu in forum Kubota Buying/Pricing
    Last Post: 02-06-2010, 08:42 PM
  4. Traded BX in for B7610
    By Killer_B in forum Kubota Buying/Pricing
    Last Post: 09-29-2008, 10:40 PM
  5. B7510 Experience compared to BX
    By pemad in forum Kubota Owning/Operating
    Last Post: 02-26-2007, 07:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
