Results 1 to 5 of 5
05-13-2010, 09:37 AM #1Member
- Join Date
- Mar 2010
- Posts
- 30
- Tractor
- BX2360
Land Pride RTR0550 vs. RTR1050
gents,
am ready to pull the trigger on a rtr land pride w/slip clutch for my bx2360.
i have two quotes, and they're about $ 220.00 apart, the rtr1050 being greater in cost & weight, tine size. . . . but offsetable if i take my quick hitch off.
is there a case to be made either way . . . i know there are number of fellows on this site that use the rtr0550 . . . but i've stumbled into the twisting my head into kruller shape with knots . . . thanks in advance for responses
regards, D902 BX PILOT
05-13-2010, 10:02 AM #2Elite Member
- Join Date
- Sep 2008
- Posts
- 2,839
- Location
- NE USA
- Tractor
- JD LA115, WH 244, WH 525 hydro-pops,Original Troy Built Horse 8 HP
Re: Land Pride RTR0550 vs. RTR1050
Dont hesitate, buy the RTR 1050 it will be stronger in breaking new ground and reopening a current garden, breaking 1/2 or 1/4 widths are more easily cut and broken as the half or three fourths already broken will offer little resistance. the more you breeak the ground the more friable it become.
Adding sand will always improve drainage and increase the ease in building raised beds which will allow early germination of seeds and reduce weet roots from heavy rains, adding gypsum destroys clay and the bonus for buying the bigger heavier unit is you can simply tear 2 inches of soil up to death at a time with the needle valve adjusment under the seat setting the height of the tiller without adjusting the depth gauge skids when breaking virgin ground when breaking ground if you want and expose the rocks and pull them out easily
dont hesitate about buyting it as it will be nothing but a plus for your needs, buying more power or strength in an implement will never be an issue as it will be something that will reduce any chance of breakdowns to a bare minimum
and you will have a stronger implement to do work.
leonz
05-13-2010, 12:23 PM #3Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,648
- Location
- Missouri
- Tractor
- Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
I have the Land Pride RTR0550 as that is what my dealer recommended. It has worked well for me on my BX2660 on all types of soil; maybe the RTR1050 will work better, just never used one.
05-13-2010, 07:41 PM #4Gold Member
- Join Date
- Apr 2009
- Posts
- 325
- Location
- St. Marys County, Md.
- Tractor
- Kobuta B2920
I have the RTR050 on my B2920 with quick hitch. It works well and covers the wheel tracks. It seems to me that you can do everything you need to do with the RTR0550 AND it's less expensive AND it's quick hitch compatible.
I'm often tillering along side a row of plantings already in the ground. No problem tillering right up next to it.
I love my quick hitch. Having to take it off to use a implement would be a hassle.Kubota B2920 tractor with RimGuard in the wheels
Kubota LA364 Front End Loader
LandPride RTR0550 Reverse Tilling 50 inch Tiller
Woods RB72 inch rear blade
Woods HC54 rotory cutter
LandPride QH15 Series Category 1 Quick Hitch
05-17-2010, 11:26 PM #5
We own an RTR 1058, they are also Quick-Hitch compatable but with the added bonus of being off-setable and to either side! The gearbox has a 3 year longer warranty than that of an 05 model and they are constructed more heavily.
The RTR1558 is a REAL HD tiller, but adds another $200 to the bill.JohnG
We have Democracy, but were founded on Liberty.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote - Benjamin Franklin (1706-1790).
I am for LIBERTY!
I Support electric trailer brakes on EVERY axle over the towing vehicle's GVW, CDLs for RVers and safety inspections on ALL licensed vehicles!
Similar Threads
Duragrader vs Landpride vs Grade Master
By NonTypicalCPA in forum AttachmentsReplies: 24Last Post: 01-23-2012, 04:24 PM -
Buying Advice Kubota BX vs. MF2400 vs. Simplicity Legacy XL
By cpb in forum Kubota Buying/PricingReplies: 18Last Post: 10-03-2011, 05:29 PM -
Bias vs Radial / Loaded vs Not
By TCR78 in forum John Deere Owning/OperatingReplies: 4Last Post: 06-20-2011, 10:28 PM -
Tractor Purchase Recommendation - Mahindra vs Kubota vs New Holland vs JD
By jascott in forum Buying/Pricing/ComparisonsReplies: 29Last Post: 04-15-2010, 11:33 AM -
Buying Advice Live PTO vs. Over-running Clutch vs. Slip Clutch
By Beervangelist in forum Buying/Pricing/ComparisonsReplies: 12Last Post: 03-21-2010, 08:46 PM
