Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Bronze Member Slice's Avatar
    Join Date
    Dec 2008
    Posts
    70
    Houston Texas
    Kubota Bx 2350
    Default quick connect for bucket / pallet forks
    HAs anyone here used this type of set up ?
    Home
  2. #2
    Silver Member srossman's Avatar
    Join Date
    Oct 2005
    Posts
    214
    Elverson PA
    Kubota BX-23
    Default Re: quick connect for bucket / pallet forks
    Quote Originally Posted by Slice View Post
    Home
    There was just a post on this very same topic. Do a search and I believe that you will find quite a few threads on this very subject. As a starter, you can read this thread:
    http://www.tractorbynet.com/forums/c...ota-front.html
    Kubota BX-23
  3. #3
    Veteran Member mikim's Avatar
    Join Date
    Feb 2001
    Posts
    2,416
    Paige Texas
    NH TC45
    What you want is a skid steer compatible quick attach for your tractor. It's pretty much an industry standard so attachments are easy to find. Getting some unique setup like you posted ..... as fancy or neat as they may be ....will make it impossible to find attachments to fit. Your dealer should be able to order it for you.
    Mike
  4. #4
    Join Date
    Oct 2005
    Posts
    214
    Elverson PA
    Kubota BX-23
    Quote Originally Posted by mikim View Post
    The problem is that no one makes a skid steer quick attach system for the kubota BX series of tractors. I agree that would be ideal, but unless you fabricate your own ssqa, you are SOL when finding a manufacturer. Right now, the link that Slice posted is the only option out there for purchase.
    Kubota BX-23
  5. #5
    Join Date
    Feb 2001
    Posts
    2,416
    Paige Texas
    NH TC45
    oh-h-h-h-h....that su_ks
    Mike
  6. #6
    Bronze Member RobKinNH's Avatar
    Join Date
    May 2010
    Posts
    91
    Fremont NH
    Kubota B3030
    I was looking at using something like this: Washburn Company & hayspear.com Quick attach Skid steer adapter hitch with blank back & heavy duty 2 cross bar frame and making the brackets to fit my loader arms. The only down fall is now your reducing your lift capacity by 100lbs.
  7. #7
    Super Member RadarTech's Avatar
    Join Date
    Feb 2008
    Posts
    5,087
    North Carolina
    2007 Kubota L3400
    Ok-- I have read a few threads.. and while I see the bucket/pallet forks etc for a QA config are great..
    I wonder how much I loose lift wise with a QA bucket?
  8. #8
    Veteran Member smfcpacfp's Avatar
    Join Date
    Nov 2007
    Posts
    1,346
    Sands Township, Marquette Co, Michigan
    Kubota B3030HSDC
    I wouldn't think you would lose anything. I have this arrangement myself. What would make you think you would lose any lift capacity?
  9. #9
    Elite Member
    Join Date
    Sep 2004
    Posts
    2,564
    Kansas, Butler county, Just east of DooDah
    Kubota L4200 GSTCA
    You are moving your load a few inches farther forward... you may loose a LITTLE but it will not be anything significant. KennyV
  10. #10
    Join Date
    May 2010
    Posts
    91
    Fremont NH
    Kubota B3030
    Quote Originally Posted by smfcpacfp View Post
    If the quick attach setup weighs 100lbs, then your lift capacity is reduced by 100lbs.
Similar Threads
  1. Handy way to move your pallet forks
    By Barely Smokin' in forum John Deere Owning/Operating
    Last Post: 06-03-2009, 11:09 PM
  2. Forks Kubota Quick Attach/BOBCAT Skid Steer Pallet Forks??
    By EastTnFarmboy in forum Attachments
    Last Post: 09-11-2007, 08:47 AM
  3. Anything Wrong with Bolt on Pallet Forks?
    By HarleyBob in forum Attachments
    Last Post: 03-15-2007, 03:56 PM
  4. Forks Pallet Mover vs. Pallet Forks?
    By aloha in forum Attachments
    Last Post: 09-23-2004, 01:50 PM
  5. Forks Pallet Forks vs. Utility Forks
    By rmonio in forum Attachments
    Last Post: 08-07-2003, 05:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
