Glow plug controller-l3600gst
   / Glow plug controller-l3600gst #1
kongmen
Columbus OH
L3600 Kubota
Can someone tell me which one out of the three units is the glow plug controller. I have read the threads on this subject and I also have the dash apart right now. All three units are on the right side and the previous owner replaced the relay on the front side and the way I understand it one of the two on the back side is the controller. If someone knows which unit is the controller I will try and replace it. I know one member used an aftermarket switch to manually power the glow plugs but unless he can send me a detailed how to I will stick with replacing the controller. The way I see it if the controller don't fix it I have three more possibilities glow plugs,engine temp sensor, timer. I just bought this tractor and will be purchasing the service and parts manual.
Kenny v I sent you a pm to see if you would consider selling your manuals to this tractor. Thanks.
   / Glow plug controller-l3600gst #2
It just so happens i have the old glow plug controller from my l4200 dt sitting here on my desk. Mine was not on the firewall but on a metal brace that was close in location to the glow plug relay which was on the firewall. It is labeled NGK spark plug co. DC12V
164156661 S33NH
   / Glow plug controller-l3600gst #3
oops here is the pic
   / Glow plug controller-l3600gst #4
I did not receive any PM...
But to answer your question.. can't sell manuals, I need to refer to them now & then myself.
If you need anything in particular let me know and I will scan and email to you.... KennyV
PS I see Kenonf covered your main question.
Thanks fellas, hopefully mine will say the same thing and look the same as that one (will have to look this weekend).
Kenny that's understandable, I just had to ask before I ordered it on line. Wonder why the pm didn't go trough though?
The controller was the problem on mine to. :thumbsup:
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
John Deere 4520 Tractor (A50514)
John Deere 4520...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
