DieselnHooters
Moral of the story could be: As good as they are you can still go wrong with a Kubota
My L5030 spends a lot of time getting whacked with limbs, and up until recently it was pretty durable. But....I happened to back under a tree with the mower and didn't realize a trimmed limb was pointed right at the seam in the rear of the cab, by the "passenger's side" work light. I kept going and then heard a huge "pop." The limb had broken and punctured the roof. Dang...Anyone else have prioblems with theirs? Mine has an upper/lower halves which are sort of welded together pieces of plastic that meet at a seam. They have split and now the roof leaks.:thumbsup: Mine also has what look like stress fractures just behind the roof mount upper front lights. I guess it's time to caulk the leaks with clear caulk. :ashamed: 3 years old and leaks.
Tractor is pretty solid otherwise, but the roof is too frail & thin/cheap for my liking.
Well, I did some research on how to fix it and with the help of the guys at Urethane Supply Company, we determined the roof is HDPE. The problem there is that nothing glues or sticks to HDPE very long, if at all. But, they make a plastic "welding" kit for just that sort of thing, and using that I was able to not only fix the puncture, but also replace two of the nuts on the inside that had shattered out from the collision.
I've got pics of it all, just need to post them up. I'll try and get that done in the next few days so anyone else that needs repairs can use that as something of a guide.
