Results 1 to 3 of 3
  1. #1
    Gold Member
    Join Date
    Dec 2004
    Posts
    325
    Washington State
    Kubota B7800
    Default HOw do I test fuel sender and gauge?
    My B7800 fuel gauge reads between about 3/4 full and full, no matter what the actual fuel level is. The gauge reads zero when the switch is off. I suspect the sender unit.
    Has anyone had this behavior? The only threads I found mentioned nonfunctioning gauges.
    I need to determine which unit is wrong. How do I test the sender? I can put a multitester across it but what am I looking for?
    Also, the only sender I ever replaced was in a Cessna which had easy access on the wing. How do I get to the sender on a kubota?
    How do I test the gauge itself?
    If anyone has done this I would appreciate some pointers. Thanks
  2. #2
    Veteran Member carpenter383's Avatar
    Join Date
    Dec 2008
    Posts
    1,059
    Indiana
    Kioti DK40SE
    Default Re: HOw do I test fuel sender and gauge?
    Does the guage move any? If not make sure the float isn't stuck.
    Sounds like the sending unit is bad, test by grounding the ground wire going to it (from the guage) and see if the guage reads 0 with the key on. With no ground the guage should be on full.
    That is typicaly the way most sending units work.
    “History fails to record a single precedent in which nations subject to moral decay have not passed into political and economic decline. There has been either a spiritual awakening to overcome the moral lapse, or a progressive deterioration leading to ultimate national disaster.” Douglas MacArthur
    "The obligation of every human being to God, is higher than his duty to country, and not even a majority in society has the legitimate right to interfere with a man's allegiance to him."James Madison
  3. #3
    Gold Member
    Join Date
    Dec 2004
    Posts
    325
    Washington State
    Kubota B7800
    Thanks
    Yes, the gauge moves. It moves from full to 3/4 when empty. I will try to look at it this weekend.
Similar Threads
  1. Oil & Fuel Branson fuel gauge fixed ! Well, maybe...
    By Cattech in forum Century & Branson
    Last Post: 03-14-2010, 03:11 PM
  2. Oil & Fuel Fuel Sender Case IH 595
    By Baytown in forum Case-IH
    Last Post: 09-08-2009, 05:57 AM
  3. Oil & Fuel Fuel Gauge on 3720 Cab stopped working
    By orlo in forum John Deere Owning/Operating
    Last Post: 05-17-2009, 08:52 AM
  4. Fuel Sender Wiring Issue
    By Baytown in forum Parts/Repairs
    Last Post: 04-07-2009, 08:31 AM
  5. Oil & Fuel fuel sender problem
    By rollbar in forum John Deere Owning/Operating
    Last Post: 06-26-2006, 11:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
