Results 1 to 9 of 9
  1. #1
    Gold Member
    Join Date
    Jul 2010
    Posts
    446
    Mapleton , Queensland , Australia
    Kubota BX2360
    Default Carry-All total weight for BX2360
    I'm looking at options for carrying around the yard ; carry-alls and
    boxes. Empty weight is around 200lb for this stuff . What do you reckon
    I could load this up to ,on a 1650lb BX2360 with MMM and no front weights ?
    Attached Thumbnails Attached Thumbnails Carry-All total weight for BX2360-showimage.jpg   Carry-All total weight for BX2360-showimage-2.jpg   Carry-All total weight for BX2360-showimagecawcwym7.jpg   Carry-All total weight for BX2360-img_0451.jpg
    BX2360 54"MMM
  2. #2
    Gold Member jb62901's Avatar
    Join Date
    Apr 2009
    Posts
    271
    Cassopolis M.
    Kubota BX2360
    Default Re: Carry-All total weight for BX2360
    Using a Carry-All is like using a FEL with out a weight box on the rear. I have used the forks with up to 750lbs with out front weight and more with the FEL on. You'll have to do some testing to see when you have to much and a need for front end weight. Be careful when doing this.
    http://i38.tinypic.com/2crr3o2.jpg
    http://i37.tinypic.com/wlytqh.jpg
    09 BX2360 FEL, + Tons of Attachments Many Homemade
  3. #3
    Gold Member
    Join Date
    Jul 2010
    Posts
    446
    Kubota BX2360
    750lb minus the 200lb of the add-on is well more than I'd
    probably load . I was thinking 300lb of compost/water for planting
    around the place. Your 3 rail-sleepers looks enough of a comparison
    for me . There's no water down the front , unless I pump
    out of a pond ( don't have a pump since there's no fire hazard up
    here ) so need to water new plantings for 6 months until the summer
    wet begins in January. Doing a tree lined drive .
    Attached Thumbnails Attached Thumbnails Carry-All total weight for BX2360-img_0344.jpg   Carry-All total weight for BX2360-img_0353.jpg
    BX2360 54"MMM
  4. #4
    Join Date
    Sep 2009
    Posts
    122
    Without a FEL on the machine I'd be cautious to carry too much weight going up that driveway. If you get too @$$ end heavy you will lift the front tires off the ground and loose steering. (Keep the carry-all as low as you can and it'll at least act as a wheelie bar.
  5. #5
    Join Date
    Sep 2009
    Posts
    122
    By the way. That view is insane.
  6. #6
    Join Date
    Jan 2010
    Posts
    1,291
    Piedmont, NC
    Kubota L4610 & BX2230, Farmall Super M, Super A
    I use a carry-all to haul a pallet that has been converted to a portable spraying setup. Carry-all + pallet + car battery + 15 gal filled sprayer + assorted stuff = about 300 lbs.
    BX does just fine with this, even without the FEL mounted. If you have the FEL installed, you could certainly go up another couple of hundred lbs.
  7. #7
    Platinum Member bikerdib's Avatar
    Join Date
    May 2010
    Posts
    553
    Texas
    Kubota B3300SU
    I can't help with the weight question but I just had to comment on your place (if that is in fact your place in the pics).
    It is B-E-A-U-T-I-F-U-L!
  8. #8
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,066
    Ontario, NY
    Kubota BX24
    Technically the BX 3 pt hitch can lift 1210 lbs only. However I have lifted alot more then that before. I am pretty sure it can lift a ton, but the issue is the leverage. a carryall will act like a fulcrum on back tires lifting front off the ground. Without a FEL and a bucket of materail for ballast, its gonna be a bouncy ride on a hill with a certain pucker factor. There seems to be no factory ready front weights for the BX, you would need to make your own if you dont have a FEL if you really want a carry all.
    I am not sure where you got the weight numbers from, 1650lbs? Are you referring to towing weight? or direct weight on the BX 3pt ?
  9. #9
    Gold Member
    Join Date
    Jul 2010
    Posts
    446
    Kubota BX2360
    The 1650lb is my machine weight , and although that is mostly
    over the rear tyres , there must be over 700lb in front of those
    wheels . What do you think ?
    This tipping transport box looks interesting ;
    http://www.hanmey.com.au/brochures/h...hure/main.html
    Page 16
    BX2360 54"MMM
Similar Threads
  1. TRAILER WEIGHT
    By bjess8 in forum Trailers & Transportation
    Last Post: 09-26-2008, 09:18 AM
  2. Ballast LB1914 drawbar tongue weight
    By gladehound in forum Kioti Owning/Operating
    Last Post: 10-15-2007, 11:17 PM
  3. JD 3X20 Rear Weight install (pics)
    By dirtworksequip in forum John Deere Owning/Operating
    Last Post: 06-05-2007, 09:59 PM
  4. bucket weights
    By dknarnd in forum Parts/Repairs
    Last Post: 05-05-2007, 11:38 AM
  5. More useful weight box?
    By tuolumne in forum Customization
    Last Post: 04-17-2007, 10:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
