Results 21 to 30 of 47
08-19-2010, 05:33 PM #21Elite Member
- Join Date
- Sep 2008
- Posts
- 2,847
- Location
- NE USA
- Tractor
- JD LA115, WH 244, WH 525 hydro-pops,Original Troy Built Horse 8 HP
Re: Winter is coming snowblower question
snow blower continued
look for other owners of the other BXs
A loader is of more benefit in winter for the reasons mentioned previously, perhaps a quck attach bucket would be better and allow you less worry with clearances and allow you to install a front blade on the loader frame instead of the bucket?
Having a blower with an extended chute will help with that issue but throwing the snow back on the ground as you advance is common place until you reach a point where you are able to get rid of it.
Many snow removal contractors have small kubotas with rear blowers and front loaders;
you should visit and become a member of www.plowsite.com and do a search for Kubota snow blowers to solve this issue.Last edited by leonz; 08-19-2010 at 11:59 PM.
08-19-2010, 11:26 PM #22Silver Member
- Join Date
- Feb 2010
- Posts
- 109
- Location
- South Dakota
- Tractor
- Kubota B3030 HSDC, Kubota ZD 18
An earlier poster stated that you can use the fel with the quick attach mounted to the frame. My local dealer told me that you cannot use the two simultaneously (B3030). Can anybody with personal experience with this set-up clarify this discrepancy?
08-19-2010, 11:37 PM #23Elite Member
- Join Date
- Sep 2008
- Posts
- 2,847
- Location
- NE USA
- Tractor
It just slapped me in the face- the front cross member will not clear the quick hitch and interfere I bet, and or the loader attachment base plates under the tractor interferes with the quick hitch mounting under the tractor(s) which make sense because of the propeller shaft and gear box.
08-20-2010, 03:13 PM #24Silver Member
- Join Date
- Sep 2003
- Posts
- 154
- Location
- MA North Shore
- Tractor
- Kubota BX1500
I have a BX1500 and a rear blower around 48".
I'm quite happy with my choice.
I like having a blower, because, as someone stated, it can fairly easily and quickly clear a significant depth of snow. A plow works best if you can go out and clear every few inches as it falls. Call me lazy.
I also must have the FEL on in the winter for other chores, and I also find it useful for clearing areas the blower doesn't work so well, like around the mailbox and backdragging a few feet from the garage door. The FEL and blower together work very well for me. I can put on the blower in the fall, and leave it there for the winter. Same with the FEL. The ability to mount/unmount them doesn't matter, as I don't until spring.
There is a lot of disagreement on the "but you have to drive backwards with a rear blower" issue. For me, it's not as easy as driving forwards, but it really isn't that bad. The HST makes it pretty easy.
And rear blowers are cheaper.
08-20-2010, 07:02 PM #25
08-20-2010, 07:47 PM #26Bronze Member
- Join Date
- Oct 2007
- Posts
- 68
- Location
- Durango Colorado
- Tractor
- BX23
Here's me moving snow last winter. You can see the narrow area behind me where the drive crosses the ditch. You can see the plow does great, I just run out of places to put it and I have to move it so far. A couple of people suggested plowing the snow into a big pile and then blowing the pile away and that seems like it would work.
08-20-2010, 07:48 PM #27Bronze Member
- Join Date
- Oct 2007
- Posts
- 68
- Location
- Durango Colorado
- Tractor
- BX23
heres the pictures, since everybody loves pictures!
08-20-2010, 08:19 PM #28
08-20-2010, 09:22 PM #29Elite Member
- Join Date
- Sep 2008
- Posts
- 2,847
- Location
- NE USA
- Tractor
08-20-2010, 10:48 PM #30
Well, well....My old friend leonz is back. How ya been.??
Great comparison of blowers right here. You see that the Puma has 25" height as compared to 26" on the Frontier. The Frontier impellar is 24" as compared to 20" on the Puma. The auger ends on the Frontier is bolted on heavy-duty with 4 bolts where as the Puma has just the 2. You can also the see that the Frontier auger has heavier re-enforcement "studs" and thicker steel. The Frontier has heavy duty adjustable skid shoes where the Puma has none. Side walls don't compare well to the Frontier, either. You can see that. One thing you can't see in the pictures is that the Frontier weighs a hefty 479lbs. The Puma just 382lbs...or is it 362lbs., leonz.?? Oh ya, look at the chains, as well. The Frontier is a #60 chain and the Puma is #50 chain.
Just look at the 2 blowers closely. I'll choose the green one everytime.
Good night, leonz.
JD770 '92 4x4 SMC FEL JD Ballast Box 6' CountyLine Back Blade 6' CountyLine Rake CountyLine CarryAll
64" Frontier Snowblower
Favorite Color....Green
The sky was yellow and the sun was blue.
Similar Threads
Chains Winter is coming...L3240 Tire Chains
By botayota in forum Kubota Owning/OperatingReplies: 17Last Post: 11-30-2008, 11:09 AM -
Winter is coming, time to make sure the lights work
By botamike in forum SafetyReplies: 6Last Post: 11-15-2008, 03:50 AM -
3-Point Hitch 3PT Snowblower question
By orlo in forum John Deere Owning/OperatingReplies: 3Last Post: 10-22-2008, 12:38 PM -
Snowblower Question
By CurtisB in forum Kubota Owning/OperatingReplies: 22Last Post: 08-24-2007, 10:18 PM -
Snowblower Hydraulic Snowblower Question ???
By Neophyte in forum AttachmentsReplies: 12Last Post: 09-05-2003, 01:58 AM
