Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
  1. #31
    Veteran Member rdsaustintx's Avatar
    Join Date
    Dec 2004
    Posts
    1,107
    Texas Hill Country
    Kubota BX-23
    Default Re: Winter is coming snowblower question
    Geez, guys. It was 103 here today.
  2. #32
    Elite Member
    Join Date
    Sep 2008
    Posts
    2,839
    NE USA
    JD LA115, WH 244, WH 525 hydro-pops,Original Troy Built Horse 8 HP
    potato, potatoe, theres nothing wrong with that PUMA.
    It would be even better with a narrow solid ribbon and Clarences impeller kit, the Frontier would benefit just as well.
    the top edge is not full width as it will allow the auger to suck down tall snow drifts without having it spill over the blower and leaving snow.
    The bearing housing is not an issue where it may be cast to accept 2 bolts or 4 bolts depending on the manufacturer, shaft diameter, shaft speed, side loading, and vibration created by the intended purpose.
    if the base edge steel is thicker anyway with a scraper curve in the rear of the housing and at the base of the sidewalls why would I need skid shoes when I want to scrape to pavement or road surface?
  3. #33
    Veteran Member JDGreenGrass's Avatar
    Join Date
    Oct 2009
    Posts
    1,578
    Maine
    John Deere 770
    Quote Originally Posted by leonz View Post
    I don't view snowblowers as "scrapers." Even if I had an asphalt driveway a one or 2 inch "base" is what would be desired.
    I am certain the Frontier would stand up to any task that the Puma would...often with better results, or should I say, efficiencies.
    Yawn.
    JD770 '92 4x4 SMC FEL JD Ballast Box 6' CountyLine Back Blade 6' CountyLine Rake CountyLine CarryAll
    64" Frontier Snowblower
    Favorite Color....Green
    The sky was yellow and the sun was blue.
  4. #34
    Elite Member
    Join Date
    Sep 2008
    Posts
    2,839
    NE USA
    Uh huh,
    green with envy when you see red
  5. #35
    DHD
    DHD is offline
    Join Date
    Apr 2005
    Posts
    113
    Farmington ME Area
    2005 Kubota B7800, Wheel Horse 416-8, Wheel Horse 416-H
    The Pronovost Puma no longer has adjustable skids ? ?
    My 2005 Puma 64 has adjustable skids,
    but they are not visible looking toward the rear of the snowblower.
    Attached Thumbnails Attached Thumbnails Winter is coming snowblower question-pumaskid.jpg
    Kubota B7800
    Wheel Horse 414-8
    Wheel Horse 416-H
  6. #36
    Veteran Member NY_Yankees_Fan's Avatar
    Join Date
    Mar 2002
    Posts
    1,960
    Warren County, NJ (60 miles from NYC)
    Gerford,
    I had a 3 pt Puma 54" with front FEL combination. I sold the Puma and went with the front Kubota blower. I was tired of doing a lot of backing up. Since you have the quick hitch already I would buy the front blower and sell the blade and put that $$ towards a cab. That is what I did with the Puma and I am happy not to have a sore neck anymore.
    AKA Tom
    #28 for the Yankees in 2013
    Kubota BX 2200, FEL, 60" MMM with Gator Blades, 48" Kioti Aerator, M96 Herd Seeder, W.R. Long Tooth Bar, 48" First Choice Tiller, Kubota BX 2750 Front Snowblower, Sims Cab, MacKissic Chipper TPH 122, Carry All, Canopy, and Weight Box
  7. #37
    Elite Member
    Join Date
    Sep 2008
    Posts
    2,839
    NE USA
    Quote Originally Posted by DHD View Post
    probably the same for rut3556's PUMA
  8. #38
    DHD
    DHD is offline
    Join Date
    Apr 2005
    Posts
    113
    Farmington ME Area
    Quote Originally Posted by JDGreenGrass View Post
    Well, well....My old friend leonz is back. How ya been.??
    Great comparison of blowers right here. You see that the Puma has 25" height as compared to 26" on the Frontier. The Frontier impellar is 24" as compared to 20" on the Puma. The auger ends on the Frontier is bolted on heavy-duty with 4 bolts where as the Puma has just the 2. You can also the see that the Frontier auger has heavier re-enforcement "studs" and thicker steel. The Frontier has heavy duty adjustable skid shoes where the Puma has none. Side walls don't compare well to the Frontier, either. You can see that. One thing you can't see in the pictures is that the Frontier weighs a hefty 479lbs. The Puma just 382lbs...or is it 362lbs., leonz.?? Oh ya, look at the chains, as well. The Frontier is a #60 chain and the Puma is #50 chain.
    Just look at the 2 blowers closely. I'll choose the green one everytime.
    Good night, leonz.
    I was researching the Frontier Snowblowers.
    Do have the Frontier SB1164 snowblower ?
    Kubota B7800
    Wheel Horse 414-8
    Wheel Horse 416-H
  9. #39
    Elite Member Rob-D's Avatar
    Join Date
    Oct 2006
    Posts
    3,061
    Catskills
    John Deere 3320
    Boy, the front or rear blower question is a tough one for me too. I had a front blower on my JD 2720 and it worked great. I loved it but the shoot cables sucked, really terrible setup.
    Now I have the 3320 and it's coming time to think about another blower. The front blower requires the front QA setup so if I need my bucket or forks for moving wood or something I have to take it off. I can leave on the BH all winter though which I like. On the 2720 I had to take off the BH to get the front blower on- PITA.
    I like the cost of the rear blower, it's a couple of grand cheaper than the front blower but looking over my shoulder sucks on my 600 foot plus driveway and the BH has to come off. Last year in the ice I slipped off the driveway into a ditch. It took three hours to dig out, I really should have gotten chains but I never needed them in the several years I've plowed with MFWD. Anyway the BH can get you out of jams pretty easily and even pull you up hills.
    So the bottom line is cost. The front blower with the QA goes for about 5 grand. Oooouch! I can get a decent rear blower for about 2 to 2.5k.
    Rob
  10. #40
    Member
    Join Date
    Mar 2004
    Posts
    39
    Squam Lake, New Hampshire
    Kubota B7800, 4x2 Gator, Polaris Ranger 400 HO
    I have over a mile of dirt road to maintain and I have a B7800 with a 60" rear mount snowblower with front loader and it has been perfect for maintaining a wide road with no snow banks. The snowblower is a JRW (Canada) and it is a terrific machine. I paid $1700 for it new in 2003 and other than a few shear bolts I have had to do nothing other than normal maintenance to it. It is a heavy gauge steel and the auger is solid.
    The front end loader adds the needed ballast - plus it makes moving snowbanks where the State plows the main road easy and it is nice to be able to scrape areas where I don't want to scape with the blower. I don't use chains and have never been stuck.
Similar Threads
  1. Chains Winter is coming...L3240 Tire Chains
    By botayota in forum Kubota Owning/Operating
    Last Post: 11-30-2008, 11:09 AM
  2. Replies: 6
    Last Post: 11-15-2008, 03:50 AM
  3. 3-Point Hitch 3PT Snowblower question
    By orlo in forum John Deere Owning/Operating
    Last Post: 10-22-2008, 12:38 PM
  4. Snowblower Question
    By CurtisB in forum Kubota Owning/Operating
    Last Post: 08-24-2007, 10:18 PM
  5. Snowblower Hydraulic Snowblower Question ???
    By Neophyte in forum Attachments
    Last Post: 09-05-2003, 01:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
