So, what IS the difference between diesel and gas engine anti-freeze? I've heard this before, but never explained.
Oh boy, I'm going to try to tiptoe around this one, as it's almost as bad as "what kind of oil to use" and I don't want to start a debate.
Even worse, there isn't just ONE difference, as there are a few different kinds of Diesel coolants. But in general...
Diesel antifreeze is a low or no-silicate formula, and has a more complicated package of anti-wear and anti-corrosion additives (SCAs), sometimes "pre-charged" or added separately. The biggest reason for the existence of Diesel antifreeze is a problem called "Cylinder Liner Cavitation", which you can Google to find out everything you never wanted to know about.
Since a) these smaller Kubota engines don't have cylinder sleeves we don't have to worry as much about cavitation, and b) Kubota calls for regular drain intervals, I'm not sure it's really critical to use Diesel-specific antifreeze. The only reason left, would be to have a very proper additive package.
My advice would be something like this:
1) Use Kubota's coolant, there's no guesswork and you can't really go wrong unless you don't follow the maintenance schedule.
2) Find the most compatible formulation to Kubota's coolant (guesswork), and still follow the maintenance schedule.
OR,
3) Invest in a good extended-life heavy-duty Diesel antifreeze if you have no intentions of following the maintenance schedule and/or ever draining it again.
But above all else,
do not mix with tapwater/rainwater, buy pure de-I/distilled water (
not spring water). Or buy pre-mixed.
