Results 1 to 7 of 7
10-03-2010, 01:40 PM #1
KUBOTA: Stupid Tail Light Question
Tractor is a L3400
I finally got around to replacing one of the tail lights that I busted last year.
I happened to notice that they are two-way bulbs like typical tail lights on a vehichle. A dim and bright element.
On a vehichle the dim is for the running/tail lights and the bright is used for brakes.
What are they used for on the Kubota???
If it has a brake switch, it isnt working cause only the dim lights up when the head lights are on. Pressing the brakes does nothing.
Owners manual was no help either. It's no big deal but it just got me wondering.".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
10-03-2010, 02:04 PM #2Elite Member
- Join Date
- Jul 2006
- Posts
- 4,342
- Location
- Northwest, WA
Re: KUBOTA: Stupid Tail Light Question
How 'bout your flashers ?
10-03-2010, 02:17 PM #3
Ford 5500 Backhoe
JD 261 3PH mower
Dolmar 7900
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
10-03-2010, 02:32 PM #4
Well it appears that only one element of the bulb is supposed to work.
In the first pic, you can see the back of the light fixture. the black wire in the middle is the common ground. The green wire on the right is the turn/flasher wire. There are two wires (red and yellow) going to the back of the tail light for the two bulb fixture.
There is a plug connector about 6" away for the lights. The red wire goes into the plug as you can see in pic 2, but doesn't continue on the other side of the plug as you can see in pic 3
I wonder why they would use a two-way light with intetions of only using 1 setting??????".........there is only one way to find out."
Ford 5500 Backhoe
JD 261 3PH mower
Dolmar 7900
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
10-03-2010, 05:36 PM #5Bronze Member
- Join Date
- Jan 2010
- Posts
- 99
I would guess....
Buying a bunch of (1/2 used, over spec'd) popular lights is cheaper than a few special lights.
10-03-2010, 07:24 PM #6
Either that or it's a light fixture they use on several different applications, one of which DOES use the second light element.
Sean
10-03-2010, 07:25 PM #7Platinum Member
- Join Date
- Oct 2004
- Posts
- 556
- Location
- New Brunswick, Canada
- Tractor
- Kubota B7800, Case 450
Perhaps brake lights are required in some jurisdictions and it's cheaper and/or less hassle to have one light assembly for all applications?
Kubota B7800, LA402 FEL, Homemade cab, 60" bushcutter, 74" rear snowblower.
Kubota RTV500.
Case 450 c/w 6-way dozer.
Similar Threads
Kubota B73 Rear Work Light Kit
By Farmall45b in forum Kubota Buying/PricingReplies: 10Last Post: 12-03-2008, 03:45 PM -
continuity of light switch question JD 650
By kmosabe in forum John Deere Owning/OperatingReplies: 6Last Post: 07-22-2007, 11:06 AM -
another ROPS light question
By jasonpotopa in forum Kubota Owning/OperatingReplies: 21Last Post: 12-30-2006, 11:46 PM -
Charge Light Question
By sls in forum YanmarReplies: 5Last Post: 10-18-2005, 10:48 PM -
Operating Opportunity - Kubota vs Kioti
By rtimgray in forum Owning/OperatingReplies: 16Last Post: 12-28-2004, 04:20 PM
