Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Join Date
    Apr 2010
    Posts
    119
    Default BX2360 Ballast box question
    I bought a BX2360 in the spring, I got a ballast box with it which I haven't used because I used my box scraper as ballast. I decided I wanted to use the box as its less bulky and I hooked it up to the tractor, only problem is that I don't think its the correct one for the tractor. The model number on the box is B5320 and the issue I have with it is the three point hitch won't lower far enough to drop it on the ground...at its lowest position its like 6" above ground level and now its empty but when I have concrete in it that will be a huge issue. Is this just how ballast boxes are or did they give me the wrong one?
  2. #2
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,922
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Default Re: BX2360 Ballast box question
    You might want to check with whistlepig as he has a bb http://www.tractorbynet.com/forums/o...s-ballast.html
    rjkobbeman also has one and there is an open thread on ballast boxes etc. good luck, I don't have one.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  3. #3
    Elite Member whistlepig's Avatar
    Join Date
    Jan 2009
    Posts
    4,267
    Preble County, Ohio
    Kubota B7800 with FEL
    Quote Originally Posted by newdeal View Post
    I have a kubota B8160 ballast box. It has a sticker on it that says "ADD 300 POUNDS FOR BX TRACTORS AND 500 POUNDS FOR B TRACTORS". I'm not sure what size a B5320 box is. Kubota website has not much info on ballast boxes. Something your dealer may have to help you research.
    I used to do the Hokey Pokey but I turned myself around.
  4. #4
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,666
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    They should lower to the ground.
    Now, two questions...does your rockshaft (3PH) lever have position control or a movable stop? If so, is it set to allow full down travel of the 3PH?
    If your 3PH is traveling full down, your question about the ballast box should be directed to your dealer since he's the one who will replace that box if it is, in fact, the wrong one.
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  5. #5
    Join Date
    Jan 2009
    Posts
    4,267
    Preble County, Ohio
    Roy is correct. It should lower to the ground. Mine has angle iron stands welded on the bottom that it sits on when I take it off.
  6. #6
    Join Date
    Apr 2010
    Posts
    119
    its aBX2360 so it doesn't have position control, it just has a level and when you hold it down it will drop the 3pt hitch until it eventually stops at the bottom...but the bottom is too high for the box to sit. I e-mailed the dealer hopefully they will either replace it with the correct one or even better give me some wheel weights instead and I will just go back to using the box blade
  7. #7
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,951
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    You could lower it onto a dolly so then you could roll it around...but something does not sound correct.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  8. #8
    Join Date
    Apr 2010
    Posts
    119
    I was just looking at the original cabs for this tractor and they show the correct ballast box in the picture...it is not like mine so obviously I got the wrong one
  9. #9
    Join Date
    Nov 2001
    Posts
    22,666
    Bethel, Vermont
    Yeah...I think it's for a BX series or a lawn/garden tractor.
    Roy Jackson
  10. #10
    Join Date
    Jul 2010
    Posts
    2,485
    Pacific Northwest
    From the wholegoods list, BX2360 takes B8160 ballast box.
    Attached Thumbnails Attached Thumbnails BX2360 Ballast box question-bx2360-ballast-jpg   BX2360 Ballast box question-ballast-note-jpg
    2007 Kubota L3130, LA723 FEL
    Land Pride FDR1672 rear finish mower, Frontier RB1172, Koyker KB60 BH
    Pallet forks, Golf cart canopy bolted to ROPS, 9" & 12" PHD
    2016 Ferris IS700Z 52" Briggs 27hp commercial turf series
Similar Threads
  1. Buying Advice Ballast Box vs Wheel Weights vs Filled Tires
    By Diavolicchio in forum Kubota Buying/Pricing
    Last Post: 11-06-2010, 09:28 PM
  2. Ballast Ballast box extension
    By Rob-D in forum John Deere Owning/Operating
    Last Post: 09-22-2010, 10:15 PM
  3. Dumb question: Why do you need Ballast?
    By newdeal in forum Kubota Owning/Operating
    Last Post: 05-02-2010, 11:33 AM
  4. Loaded Tires vs. Ballast Box
    By robertwhite in forum Buying/Pricing/Comparisons
    Last Post: 04-17-2010, 02:44 PM
  5. Ballast Ballast Box
    By NYBOB in forum John Deere Owning/Operating
    Last Post: 09-22-2007, 11:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
