Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    New Member
    Join Date
    Oct 2010
    Posts
    11
    rural mountains - Montana
    Kubota M59
    Default It's Grapple Time
    Any of you have a problem with bending and breaking things? I do. So when I decided to get a grapple I got one of the toughest ones I could find. I live in the rural mountains of Montana about the 5000 foot level. Where I am we don't have alot of brush or thickets, but we do have rock and large ponderosa pine trees. Unfortunately about 2 years ago pine bettles started killing off the trees and we got hit bad. It's hard to believe how a little bettle can cause so much devistation, not to mention the fire danger as the trees dry out. I figure it will be 2+ more years before I can get all the dead trees down and the limbs and branches cleaned up.
    I did alot of reading on TBN about grapples and what everyone was recommending. The pros and cons went back and forth, with some very stuck on what size of grapple you should get. I ended up deciding that everyones input and experience was great information but the bottom line is that there are many local factors to consider when buying a grapple. I looked at what my conditions were, how I would be using the grapple, the size of my M59 tractor, the FEL lift capacity and of course could the budget afford it. I think it boiled down to these 3 needs or requirements.
    1. The grapple must be at least as wide as the tractor. When picking up branches after delimbing an 80 foot plus tree I don't want to be driving over 1-6 inch branches much less having them poke at the tires or Big Orange. I sort of look at it like you wouldn't buy a 4 foot snow blade for a 6 foot wide truck would you?
    2. The grapple had to be strong enough to grab and hold onto at least a 16 foot section of a tree. I use 16 feet because many trailers around hear are 16 feet long for transportaion. I will admit that there has been a few cases when a 16 foot section was just too heavy even for the M59. And it was sad to lose a big tree like that.
    3. I needed to build some rock retaining walls so the upper tines of the grapple needed to extend out approximately the same as the lower tines. I also estimated it needed to be strong enough for a 3000 pound piece of rock. This would allow me to pick up the rock with the outer edge of the grapple and let me lean out of the tractor and have a better view of where I was putting it. Of course I can only lean out so far or I will trip the seat safety switch. But that is ok I like safety.
    After looking at my needs/requirements and my Big Orange which has a lift capacity of almost 4000 lbs (excluding implement) and a breakout force of almost 6000 lbs, I concluded for my situation I needed a serious grapple. They make bigger ones but this fit my needs and it is one bad boy.
    Anbo GR-SH 6' Site-Pro Heavy Duty Grapple Rake, 6" spacing. The tines are 5/8" and outer tines 3/4" made of AR400 Steel, 3x8 cylinders with a 51" opening, weighs in at 1005 lbs.
    Excluding the cost (don't ask) I have been super happy with the grapple. It is the most used implement I have, not counting winter time. My wife now calls the M59...JAWS.
    I would also like to say if you are looking at getting a grapple use your judgement based on "your" situation and needs. One size does not fit all unlike what others may say.
    Happy Grappling...M59 Jim
    Attached Thumbnails Attached Thumbnails It's Grapple Time-grapple1.jpg   It's Grapple Time-grapple2.jpg   It's Grapple Time-grapple3.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Jun 2006
    Posts
    551
    PNW - Washington - The Evergreen State
    2006 Kubota L3400
    Default Re: It's Grapple Time
    wow, that is impressive. i can tell it's going to get alot of use. i am curious to know how it works for placing rocks on walls, i've done some walls of my own using a mini-ex with hyd thumb. took a long time but was pleased with the results.
    cheers,
    bigballer
    L3400hst (300hrs) w/ la463 fel, backhoe, toothbar, brushhog, boxblade, rake
  4. #3
    Elite Member rswyan's Avatar
    Join Date
    May 2004
    Posts
    3,727
    Northeast Ohio
    Kubota B2910, Simplicity 18 CFC, Cub Cadet 782
    Sweet piece
  5. #4
    Platinum Member jgrreed's Avatar
    Join Date
    Jun 2008
    Posts
    780
    Regina, Saskatchewan
    JD 4720
    Wow, that things heavy-duty! Good for you for spending what you need to on quality equipment to fulfill your requirements.
    Enjoy.
    -Jer.
    ________
    2005 JD 4720, 400x loader with bucket, bale spear, pallet forks, Markham LD grapple, Markham snow blade, Schulte BX 74 snowblower, Caroni 1900 flail, 8' Aerway, 3rd SCV at rear, hydraulic toplink from CCM, LED lights front and back, added EH hydro circuits, big pile of 3pt implements.
    Wish List:
    PTO hydraulic pump to run custom fab'd hydraulic snowblower, broom, weed wacker, or PHD. Side link from MtnView Ranch....
  6. #5
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    11,418
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC 2042
    That beast looks hungry..nice setup.
  7. #6
    Veteran Member Deano's Avatar
    Join Date
    Oct 2008
    Posts
    1,046
    Southern Maryland
    Kubota BX24
    I think you can pick up my little tractor no problem!! If I ever get stuck in the mud, I will call you!!
    Deano
    Deano
    2006 BX24, 6' New Implements rake, Woods RB60 rear blade, Wallenstein thumb, Bro-Tek rear skid plate, home made front skid plate, W.R. Long flat tooth bar, 4' finishing mower (TPH), 4' box blade, post hole digger, New style seat!!!!! Country Manufacturing manure spreader, Agri-Fab drop spreader.
  8. #7
    DRD
    DRD is offline
    New Member
    Join Date
    Feb 2010
    Posts
    15
    Super nice, if i get a log i cannot handle with my L48TLB, (JR Long Grapple) down here in Wyoming will you come give me a hand ??
  9. #8
    Join Date
    Jun 2010
    Posts
    218
    Northern Illiniois
    Kubota L5740 HST
    No argument what - so - ever!!! I leave the grapple on the tractor when it's not going to be used because I know I can do "Something" with the grapple. I also went with Anbo...as have many others because of their reputation and quality. It makes property clean up a joy versus a chore. Watch your rear end!!!!
    Safety first!
    Proverbs 1:32
    "For the waywardness of the naive will kill them,And the complacency of fools will destroy them.
    Keep your ROPS up, your bucket low and plenty of weight to counter your FEL...
  10. #9
    Platinum Member powerstroke444e's Avatar
    Join Date
    Jan 2008
    Posts
    987
    Near Springfield IL
    Several
    I made one just like yours and after way to much welding I would have been better off buying on. I have managed to to bend the end tines on mine but I agree next to the backhoe with grapple the front grapple is most used item on the tractor. I would agree its worth every penny.
    If it ain't smokin' it's broken.
  11. #10
    Gold Member
    Join Date
    Sep 2004
    Posts
    488
    Nashville, TN / Hickory, NC
    Kioti DK55C
    Quote Originally Posted by powerstroke444e View Post
    I have a little lighter weight grapple on my tractor and find it does great. I don't plow the ground and not sure my tractor has the power to do it. What is does do is allow me to move brush piles. I spent a fair amount of time last week cutting trees out of a fence row and found this invaluable in moving the droppings. I keep mine on all the time but sometimes wonder if all that weight bouncing that far out is not a strain. It does help very much to balance the bush hog(7') and vice versa.
    Attached Thumbnails Attached Thumbnails It's Grapple Time-img_5996.jpg   It's Grapple Time-img_6046.jpg   It's Grapple Time-img_6053.jpg
    Nashville/Hickory
    Kioti DK55c(no longer for sale), Hustler SuperZ, 72 Box Blade, Stihl HT101, International Machines 7ft Mower, Liebherr 631B, RV7
Similar Threads
  1. Thumb Please Help.....Grapple or Thumb?
    By trook in forum Attachments
    Last Post: 01-15-2010, 03:02 AM
  2. Dual action grapple
    By hr3 in forum Build-It Yourself
    Last Post: 03-31-2009, 05:50 PM
  3. Grapple Grapple or Loader
    By laen64 in forum Attachments
    Last Post: 03-30-2009, 01:05 PM
  4. Grapple Ebay Grapple
    By wickedinhere in forum Attachments
    Last Post: 10-05-2006, 06:55 AM
  5. History of Time...
    By JohnMiller3 in forum Related Topics
    Last Post: 04-07-2002, 06:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
