Loader Just acquired a B6100 and wanting a loader
   / Just acquired a B6100 and wanting a loader #1
Jerryandtigger
Kubota B 6100
I am in austin texas and any and all advice on getting an aftermarket loader will be appreciated.
   / Just acquired a B6100 and wanting a loader #2
Congrats on the B6100 - you'll love it. I have one and love mine.
Is yous a gear or hydrostat?
Mine has a Kubota B219 loader so if you can find one of those, you'll know it will work.
   / Just acquired a B6100 and wanting a loader #3
You may find that it is cheaper to buy a tractor with a loader, unless you get really lucky.
   / Just acquired a B6100 and wanting a loader #4
I have a B1630 FEL, there's also a 1630C that is supposed to allow for a belly mower. A used loader will not be easy to find but any that fit a B6100 or B7100 should work. These are tough little tractors.
Thanks, it has a 3 point hitch 4' mower. I would like a loader, post hole digger, and blade. I hear that there are several after market loaders but I have not found one that I am sure will work. I will post more about the tractor tomorrow. The price was right but it could still be a money pit.
   / Just acquired a B6100 and wanting a loader #7
You might take a look at RCO Tractor in Austin. They sell koyker loaders and parts.
   / Just acquired a B6100 and wanting a loader #8
I did very well with a Bushhog loader on my old B8200HSTD. I bought it with just a 3pt mower and scraper, then saved up for a loader. I used the smallest Bushhog QA loader for about 10 years.
Having been around TBN since it's infancy, I will tell you the used loader market is practically non existant.
Having bought a loader, I would warn you to be ready for sticker shock. Mine was $3150.
That's right, over $3k!
At the time, a Kubota loader was a couple hundred more expensive. And, because they did not have a mount kit for my slightly older tractor, Kubota would have had to cut and weld a newer mount kit to make it fit.
These appear to be the latest version of the loader I had; the smallest available.
Compact Loaders 1847QT
Compact Loaders 1045
Had a friend with a 30hp Massey; it had a Koyker loader. Worked fine too.
The loader I bought is still going strong. I know the guy that bought the B8200 when I moved up to a larger tractor.
   / Just acquired a B6100 and wanting a loader #9
If you can find a Kubota loader for your tractor, I'd take it. The ease of installation/removal of the loader once it's mounted is easily worth severall hundred $$$'s in my opinion.
However, since you may not be able to find one, I bought a Koyker for a grey-market tractor I once owned. They are very well built and a good company.
   / Just acquired a B6100 and wanting a loader #10
That B6100 is older than my B8200 was. Kubota could surely fit a new loader to it. But, they would have to hack apart and rebuild the frame at the dealer. That was a part of why I went aftermarket; Bushhog had the subframe to fit my tractor.
I do like the fit/finish of my NH factory loader. Prefer it to aftermarket. The OP is 99% wouldn't have that option.
2014 Ram 2500 Pickup Truck (A55973)
2014 Ram 2500...
2017 Wanco WSDT3-S S/A Towable Radar-Speed Trailer (A55973)
2017 Wanco WSDT3-S...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2020 PRAT TL (A55758)
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
1990 LOAD KING BELLY DUMP (A58214)
1990 LOAD KING...
