Front cargo/ballast box
   / Front cargo/ballast box #1
Bluelick
Kentucky
Kubota B7100
I have been carrying wood with my "new to me" carryall on my 1984 B7100 HST-E. I have found that I can only put about half the wood the carryall will hold on it before it starts to lift the front of the tractor. Plus side, I have been learning about how to steer using the brakes! Aside: It's oddly hard to do this with the brakes and hydro pedal both operated by the right foot. I've been carrying a stick to push the hydro pedal while braking. Awkward.
Anyway, back to my question. I know I could put weight on the front but it seems that if I could make a reasonably good sized box that would mount on the front, then I could fill it with wood also, and not be carrying excess weight when the carryall is not loaded. And I could haul more wood in one load.
Anybody done this or seen something like this? Of course, those with FEL's already have this option, but an FEL is not in the cards for me, and I don't need anything to go up and down, just a fixed box, but it needs to be big enough to hold enough wood to provide the needed counterweight.
Thanks!
   / Front cargo/ballast box #2
Go for it! We have farm customers that build rock boxes for when they are fitting the fields to carry the rocks off the fields.
   / Front cargo/ballast box #3
LOL! I used to have a B7100HST (and an older B7100DT before that). Great little tractor! Maintain it well, and it will outlive you.
Both my B7100's had FEL's, but the later HST one had an aftermarket quick-attach Woods FEL. I never realized how much counterweight the empty FEL until I started moving pallets of firewood with the carryall on the back, and tried it one time with the FEL off.
Anyway, back to your question; a front cargo box is a great idea. If it were me, I'd obtain, or have fabricated a front weight bracket, and then a box that can hang on that. That way, if you want some weight on the front w/o the extra length of the cargo box, you can hang normal front weights on it.
Also, I don't know how much snow you get in KY, but if you get snow, you might want to get a front blade for it. The blade will double as a counterweight.
   / Front cargo/ballast box #4
I had the same problem with my BX2660 when I moved my 4 place enclosed trailer last year. I made a front box that slides on the front where the attachment goes for the snowblower. Now I can fill my carrier on the back and place weights, chainsaw and supplies in the front. Just for carrying those things you need it. I might put a chain hanger on the box yet, so I dont have to dig for the chain inside the box.
Jeff
I've been puzzling over this for several days now and a plan is beginning to take shape, I'd like to know what you all think. I'm thinking about fabricating a way to mount a Reese-type receiver on the front. Then I can just stick in one of those cargo carriers they make to go on the back of a vehicle. The one's I've looked at are rated for 500 pounds, so that should do nicely. Then I could remove the carrier easily and use the receiver to mount other things, like a winch or a trailer hitch to move my boat around. Anybody done something like this? Thoughts on the best way to mount the receiver? Above or below the front frame member?
Here is the kind of carrier I'm considering:
http://www.northerntool.com/shop/tools/product_200442143_200442143
Thanks!
   / Front cargo/ballast box #6
Wel-Bilt Steel Cargo Carrier | Receiver Hitch Cargo Carriers | Northern Tool + Equipment
Thanks!
I like your idea.
Hey Jas67,
Nice pile of wood on the carryall in your picture! What model tractor is that and do you have anything on the front for balance?
I've spotted this receiver at Harbor Freight:
5000 Lb. Capacity Step Bumper Receiver
It's even on sale for $21.99. I think I can hang it on the front frame extension with some J-bolts. I'll let you know how it goes.
I also spotted this "step" that should make a nice front bumper when I'm not using something else:
27" Hitch Step with Pin
If I manage to get this working, I'll post some pictures.
   / Front cargo/ballast box #9
Bluelick said:
Hey Jas67,
B7100HST. It has a Woods Dual 145 FEL.
I've since replaced it with a B7610.
OK, made it through Christmas and finally got back to this project! I got the hitch receiver mounted today. I started by making some blocks to fit inside the front frame extension that would keep the bolts from being able to shift around.
I used 1/2" grade 8 bolts, but the holes in the hitch receiver were 5/8", so I sunk bushings into the bottom side of my wood filler blocks to take up the space.
I used a bracket I had left over (from another hitch installation on a car I no longer have) to clamp across the top of the frame extension. The wood blocks might not have been necessary but seemed like a good idea.
Here is a side view:
I then assembled and mounted the carrier I got at Harbor Freight, which is supposed to be rated for 500 pounds, so with that full of wood it should make a decent front counterweight to my carryall.
By then it was cold and dark, so I'll have to try it all out another day!
One nice thing about the hitch receiver is that now I can easily mount a variety of other useful items there, such as a winch, a trailer ball, etc. Oh boy, more toys!
Happy New Year to all!
Toro Groundsmaster 3500-D Sidewinder 3 Deck Rotary Commercial Mower (A56857)
Toro Groundsmaster...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Portable Restroom (A54865)
Portable Restroom...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
