Oil Dip Stick location after alternator mod on B3200
   / Oil Dip Stick location after alternator mod on B3200 #1
JTPass
New Hampshire
Kubota B3200
I just had the 40A alternator upgrade done on my B3200. It was installed by a local dealer. I went to check my oil yesterday and couldn't reach the oil dip stick from the top. I had to reach under the side cover to get at at and then it was not easy. I recall there was an extended dipstick that came with the alternator install kit. Does anyone have any more information on this? I would like to be "armed" with information before I contact the dealer.
   / Oil Dip Stick location after alternator mod on B3200 #2
The original dip stick works fine all that needs to be done is to bend it out of the way of the new alternator. The dealer should still have it.
   / Oil Dip Stick location after alternator mod on B3200 #3
If anyone has a description and or pictures of how this is done, I would love to be able to check my oil without removing the side engine cover on my B2630!
Thanks,
Rob
   / Oil Dip Stick location after alternator mod on B3200 #4
Anybody?
-Rob
   / Oil Dip Stick location after alternator mod on B3200 #5
Rob...
I installed the alternator kit on my B7800 after one winter with my heated cab. (The dynamo just could not keep up with the heater fan and the work lights.)
I didn't like the dinky dipstick that came with the alternator kit (had to remove the side panel to check the engine oil.) A TBN'er advised that you can tweak the bends in the original dipstick tube to fit around the alternator. It's a tight fit in my case beacuse my cab heater hose is also in there, but I was able to make it work. I cable-tied the dipstick tube to the heater hose where it is supported by a bracket I fabricated. See the attached photos.
The dipstick isn't as smooth re-inserting in the tweaked tube, but I find it much better than having to remove the side panel. Hope this helps
   / Oil Dip Stick location after alternator mod on B3200 #6
I was able to bend the dipstick tube on my B3030 without too much trouble. I didn't want to take off the front grille and the side cover just to check the oil, either.
