Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Bronze Member reed52's Avatar
    Join Date
    Mar 2010
    Posts
    65
    Southern IL
    Kubota BX2400
    Default Rear Install Work Light
    On a BX24 is there any wiring set up for a work or rear light ready to go from the factory? I can cut into wires and get one hooked up but was trying to make it easier...
    Thanks,
    Reed
  2. #2
    Bronze Member Chad450r's Avatar
    Join Date
    Dec 2008
    Posts
    51
    Default
    Quote Originally Posted by reed52
    Thanks,
    Reed
    I ran a new wire from the battery with a fuse to a switch and then back to the ROPS really the best way IMO
  3. #3
    Member
    Join Date
    Dec 2010
    Posts
    30
    MX5000
    Default Re: Rear Install Work Light
    Work light attachment on a MX 5000. Factory installed, pretty simple.
    Attached Thumbnails Attached Thumbnails Rear Install Work Light-dsc02962-jpg   Rear Install Work Light-dsc02959-jpg
  4. #4
    Veteran Member CHDinCT's Avatar
    Join Date
    Jul 2008
    Posts
    2,457
    Conn. & Florida
    Kubota BX25
    Default
    Should be taped up right under or near the top link bracket. Look for a bulge of black elecrical tape.
    Chris
  5. #5
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,880
    Ontario, NY
    Kubota BX24
    yeah-- your BX24 already has wires for light. I didnt use em since I needed more wattage. I used the wirs for the sprayer instead. The wires is taped up in back of BX hidden in wire loom.
    I included the pics of wire location I posted many times....
    Attached Thumbnails Attached Thumbnails Rear Install Work Light-bx24-exposed-wire-connections-jpg   Rear Install Work Light-light-harness-location-jpg
  6. #6
    Join Date
    Mar 2010
    Posts
    65
    Southern IL
    Kubota BX2400
    Thanks for the help, the wires are there, will make a lot easier to hook up!
    reed52
  7. #7
    New Member
    Join Date
    Jun 2008
    Posts
    17
    Ohio
    Kubota BX2200, Farmall Cub
    I didn't use mine, but just to be curious, are these wired in as constantly hot? Or do you have to flip your headlights switch?
    We are what we repeatedly do. Excellence then, is not an act, but a habit.
  8. #8
    Join Date
    Jul 2008
    Posts
    2,457
    Conn. & Florida
    Kubota BX25
    Quote Originally Posted by MidgetMaestro View Post
    Mine is hot whenever the key is on. You will need a switch or switch and relay if you use it for work lights.
    Chris
  9. #9
    Veteran Member MikeInEburg's Avatar
    Join Date
    Feb 2008
    Posts
    1,043
    Emmitsburg, MD
    Kubota B7800
    I don't think that I'd want ROPS mounted lights to activate with normal headlights - as there are many times where the std lights bounce off of the loader. Separate switch would be much better.
    Mike
    "As you go through life, make this your goal: watch the donut, not the hole"
    Kubota B7800
    BH-75A Backhoe
    Rhino 60'' finish mower
  10. #10
    New Member
    Join Date
    Jun 2008
    Posts
    17
    Ohio
    Quote Originally Posted by CHDinCT View Post
    Does kubota have a switch on their utility light? I couldn't imagine always running it...
    Since I don't have an FEL, I tapped in through the tail light for my rear-facing utility lights, so I have to consciously turn on my headlights, and then pull the switch for the lights. I don't need to be running down the road, blinding some poor motorist...
    Quote Originally Posted by MikeInEburg View Post
    Mike
    Right. Especially if any of them are rear-facing!
Similar Threads
  1. Replies: 14
    Last Post: 03-10-2009, 12:20 AM
  2. Work Light On 2615
    By whiteh2o in forum Mahindra Owning/Operating
    Last Post: 03-27-2008, 09:29 PM
  3. Kubota won't start
    By IanM in forum Parts/Repairs
    Last Post: 09-12-2006, 09:31 AM
  4. 2210 Rear work light and rear blade questions
    By bkennedy in forum John Deere Buying/Pricing
    Last Post: 11-30-2005, 04:54 PM
  5. cub cadet 7265 rear work light
    By KThandy in forum Cub Cadet Tractors
    Last Post: 02-09-2005, 08:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
