Kubota Hydraulic rear remotes
   / Kubota Hydraulic rear remotes #1
Agrantina
West Tennessee
Kubota L3240 GST
ok-newbie question on rear remotes. In this ETA pic this L3240 has 2 rear remotes- my pic with arrow. I would think that is what these are..Questions are...
1. what are these rermotes used for
2. what rear implements need remotes
3. does a hydraulic top link work off one of these remotes?
4. basically what are they a must have for??
AndyG
   / Kubota Hydraulic rear remotes #2
They can be used for snowblower hydraulic chutes, hydraulic top links, hay baling equipment... and the list goes on and on.
   / Kubota Hydraulic rear remotes #3
Actually that is ONE remote, not 2. They come in pairs - One for each side of a double-acting cylinder
   / Kubota Hydraulic rear remotes #4
1 - Any thing you want ; links, implements, ect...
3 - Yes
E/S
So that is one in the pic not 2 remotes.. Can a log spliter be run off one like that? I would guess that there is some type of control lever like a FEL loader has? is that mounted somewhere close to the FEL control lever?
AndyG
   / Kubota Hydraulic rear remotes #6
Yep, that is one single remote. Yes, there is a lever for it. It is usually right beside the 3pt. up/down lever.
   / Kubota Hydraulic rear remotes #7
The remotes in the pic will operate 1 double acting cylinder. Power to extend and power to retract.
You could operate a top link cylinder.
You could operate a side link cylinder.
Hook the hoses to a front grapple.
A chute rotator on a snow blower.
Log splitter? Depends
Thanks-I am understanding more and more..Looking at the Kubota site I was wondering what the differences are with the FD with lever and standard with lever kit is??? This is off the Kubota site...
AndyG
   / Kubota Hydraulic rear remotes #9
I added a single remote on my Brother's L3240. I've attached a couple pics but don't have one showing the lever with the tractor assembled. The remote lever is just behind your 3pt lift lever. There are slots in the fender assembly to add three remote levers. The hydraulic connectors at the rear of the tractor are stacked together as you add more remotes.
My Brother got his kit from the dealer he bought the tractor from, supposedly at the dealer's cost, $450. It took me about an hour to install. Had to remove the seat platform and take two bolts out of the ROP assembly. Then remove the small plate on top of the hydraulic pump unit and install the kit. Pretty simple.
Kubota is always expensive when adding their factory kits. But to get an "out of the way" setup this is pretty slick. I'm guessing he can probably add an additional remote for $300 since he wouldn't have to buy the hydraulic adapter plate, lever stand and remote connector stand again.
Thanks-thats some good info...Once you get a pic of the lever and mount please post.. I am just trying to learn more about remotes and what they can do... Got to play around a tractor the other day with a hydr top link.. That was sweeeeeet..:)
AndyG
City of Lakeland (A51691)
City of Lakeland...
Polaris Side by Side (A50324)
Polaris Side by...
Ground Works Fertilizer Spreader (A51573)
Ground Works...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
LANESHARK LS2 LOT NUMBER 159 (A53084)
LANESHARK LS2 LOT...
