wawajake
I presently use my ATV with a 60 inch manual swivel Moose snow plow for most of my 300 ft driveway winter maintenance , and then the odd time push back the banks with the FEL on my BX2660 tractor and maybe back scrape a few sidewalk sections. The ATV is quick but it is cold out there. SO last night I was looking at the plow and possibility of attaching it to the back of the BX tractor while maintaining the plow so that I can still attach it to the ATV if I want at a later time .( so attachable to both machines when need be) So I don't want to cut the frame and mount it to the FEL or bucket like others have done here.
ATV plows come with a roughly 5 ft long frame made of 2 pieces of 1 inch square stock that slides under a ATV and with ears welded on the end of the frame that slide into ears already mounted under the ATV , with two half inch pins to let it swivel up and down. Of course the other end of plow closer to the plow blade has a place for the ATV winch to move plow up and down.
Of course the plow section itself also swivels at that same mount plate to plow right or left or flat.
Now on the BX tractor I see where there is a nice mount plate at the lower rear with a hole for a trailer hitch . But I think I could weld up a small 8 inch plate to bolt on there with similar ears for the half inch pins to fit the ears like it does under the ATV. Then that frame would be underneath my Kubota weight box , and plow would face back wards with room still for it to swivel.
Then to lift it up or down I think I could use something at the back of the weight box ( short chain and clip maybe) to attach to the exisiting lift point on the plow , and use the threepoint hitch to lift the weightbox up and down, thus lift the plow up and down.
Now my question is do people here see any major flaws to my preliminary thinking? I have a homemade cab on the tractor and so I am out of the wind and it does not seem that hard to drive backwards looking out the back. I suspect if I have it in rabbit instead of turtle speed when snow is light I could be fairly fast. I like that I would still have FEL free to do forward work (EG windrows of snow , back scraping, and pushing banks. I think if I adjust the shoes on the plow I could prevent it digging in if my mounting angles are different than on ATV, and plow already has those double springs that kick the plow flat if I hit something hard.
What thinks you all , I do prefer the seat time on the tractor versus the ATV.
