Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    New Member Searay45DB's Avatar
    Join Date
    Nov 2010
    Posts
    24
    Chadds Ford, PA
    Kubota G 1800
    Default Snow Blower just isnt right. Blower is a blower, right?
    Last weekend, I discovered the hard way that my wife put some landscaping rock on the walk to our door.I have a TG2742 kubota two stage blower, it's on the front of my G1800. The fan was shot. I ordered in a new fan, auger bearings and figured out eventually that you disconnect the shaft from the chain sprocket so you can pull the whole unit out. Put the auger bearings in, although they don't go all the way into the shaft, that took 3 hours to realize. So now, when I turn it on, it seems out of balance. The only thing I notice is that the gear box is more on one side than the other. How do I know? When I put the shear pins back on, there is no space between the auger and the gearbox on one side, and about 1/4" on the other. The side with the quarter " has more space in general I have the bearings installed in the same place, as there are markings from where the first set was.
    Fan clears fine, no noise, just the gear box is over a little.
    Suggestions? This is a two stage, so it has to be something simple. Naturally Kubota has no service manual.
    Need some help from all you two stage snow blower experts!
    Thanks!
  2. #2
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,604
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    Default Re: Snow Blower just isnt right. Blower is a blower, right?
    Quote Originally Posted by Searay45DB View Post
    Thanks!
    Are you sure something isn't bent?
  3. #3
    Veteran Member kevinj's Avatar
    Join Date
    Jul 2003
    Posts
    1,379
    West MI
    BX-1860, L3940HSTC, B7500, Farmall M, Farmall 560D
    So, loosen BOTH auger bearings and slide the shaft over, tighten bearings.
    Oh and as said, be sure things are not bent.
    Pictures would help as not many of us have that model.
    Kevin
    BX1860, mower, snowblower - B7500HST, FEL, Bush Hog - Grand L3940 HSTC, FEL, snowblower, 6' Landpride brush hog, 6' King Kutter tiller, Corn Pro 18+5 Fifth Wheel, 1950 Farmall M, Farmall 560D
  4. #4
    Join Date
    Nov 2010
    Posts
    24
    Chadds Ford, PA
    Kubota G 1800
    Default
    Quote Originally Posted by kevinj
    You can move shaft over, but that does nothing as the shaft is keyed and can move freely either way. Shafts are not bent. Fan was, replaced it. There are three bearings. 2 auger and one shaft. I had the auger bearings tightened down and one of the last steps was to put the shaft bearing in, and it was tough. Sitting hear wondering if u don't tighten the shaft bearing first, then finally do the auger bearings. This is where a manual would be really helpful. Will post some pics.
  5. #5
    Join Date
    Jul 2003
    Posts
    1,379
    West MI
    On my blower the auger shaft can slide back and forth in the gear case. I centered it, straightened the housing. The housing and auger bearings are all that hold the shaft on mine.
    The worm gears try to push it to one side.
    Kevin
  6. #6
    Join Date
    Nov 2010
    Posts
    24
    Chadds Ford, PA
    Kubota G 1800
    Ok. but When I disconnect the bracket, I can move the gear box over, butit wants to go back to where it is. Do I have to loosen the shaft bearing in the housing?
    I follow you, but when nothing is supporting the gearbox it, it wants to be off center I guess. When I put the last bearing on(shaft bearing) , it was a bitch, wondering since i had the auger bearings installed, it determined the placement of the gear box.Is this more of a sequence order?
    Follow? Here are some pics.
    Attached Thumbnails Attached Thumbnails Snow Blower just isnt right.  Blower is a blower, right?-dsc_0622-jpg   Snow Blower just isnt right.  Blower is a blower, right?-dsc_0624-jpg   Snow Blower just isnt right.  Blower is a blower, right?-dsc_0625-jpg   Snow Blower just isnt right.  Blower is a blower, right?-dsc_0626-jpg   Snow Blower just isnt right.  Blower is a blower, right?-dsc_0629-jpg
  7. #7
    Join Date
    Jul 2003
    Posts
    1,379
    West MI
    Loosen the AUGER bearings on the outside housing and move the auger shaft over to center it.
    What are you calling a shaft bearing????
    Kevin
  8. #8
    Join Date
    Nov 2010
    Posts
    24
    Chadds Ford, PA
    Kubota G 1800
    Quote Originally Posted by kevinj View Post
    The housing bearing...lossen that to center, then the auger?
  9. #9
    Join Date
    Jul 2003
    Posts
    1,379
    West MI
    What is a housing bearing????
    There are bearings on the drive, on the impeller shaft and on the auger ends.
    Kevin
  10. #10
    Elite Member zzvyb6's Avatar
    Join Date
    Dec 2006
    Posts
    3,589
    michigan
    jd 1070
    First off I'd say it is out of balance as far as snow delivery to the fan. Is one auger flight is off by 180 degrees? The collection action ought to be chuting the snow into the fan. That's not going to happen the way the picture seems to show in your machine. Give us a picture of the entire front of the unit.
    Secondly, it looks to me like the gearbox bracket is bent to the side, perhaps because of the large torque hit when it stalled. That gearbox input shaft ought to be square with the frame. Say it ain't so.
    Here's a shot at what the auger alignment ought to look like. The auger is essentially a rotating funnel.
    There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
Similar Threads
  1. Rear snow blower or front mounted snow blower
    By Doc_Bob in forum New Holland Buying/Pricing
    Last Post: 10-29-2012, 12:04 PM
  2. Snow Equipment Owning/Operating Snow blowing rules of thumb
    By smfcpacfp in forum Snow Removal
    Last Post: 02-13-2010, 03:41 AM
  3. Snow Snow blower for B7610(24hp/18PTO), 50" or 60"
    By jas67 in forum Kubota Owning/Operating
    Last Post: 09-07-2009, 09:28 PM
  4. Snow Front Snow Blower or Front Snow Plow?
    By FRIZ in forum John Deere Owning/Operating
    Last Post: 05-23-2009, 10:38 AM
  5. Snow Attachments Why all the different snow blower brands?
    By Wyld Bill in forum Snow Removal
    Last Post: 03-13-2008, 03:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
