Results 1 to 7 of 7
  1. #1
    Join Date
    Nov 2007
    Posts
    790
    PA
    Kubota L3130 HST 4x4
    Default Oil drain plug size?
    Can someone tell me what size threads the motor oil drain plugs are on L3x30 tractors?
    I want to pick up a couple of seal washers prior to the next oil change. I am probably going to switch from what looks like copper washers to ones with rubber o-rings built in. Currently there is a slow drip from one of them and retorquing didn't stop it.
    FYI I looked up the parts on several websites and none of them gave the thread sizes.
    Attached Thumbnails Attached Thumbnails Oil drain plug size?-seal-washer-2-jpg
    Attached Images Attached Images
    Kubota L3130 HST 4x4, FEL LA723 w/QA and BH90 Backhoe
    Kubota L4740-3 Cab, HST, FEL w/Heavy duty bucket w/cutting edge
    Snow Blower: L2185 72" front mount w/hyd rotation and electric chute, 7' back blade, carry all, 48" Pallet Forks w/QA, Sun Shade, Turf tires & Rubber Chains for the winter, Extra forward and rear lighting. BearCat 73454 Wood Chipper. LandPride RCR2672 Rotary Cutter. Ballast Box Approximately 390 hours on L3130
  2. #2
    Join Date
    Nov 2007
    Posts
    790
    PA
    Default Re: Oil drain plug size?
    In case it helps anyone else the threads for the engine oil drain plugs is M12x1.25
  3. #3
    Join Date
    Nov 2007
    Posts
    790
    PA
    Washer: Oil-Tite 65724
    Cost: $3.99 form AutoZone for package of 2
    Attached Thumbnails Attached Thumbnails Oil drain plug size?-photo-jpg
  4. #4
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,918
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Good information to know, I haven't had any leaks with mine, but now I know what to do if I do.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  5. #5
    New Member
    Join Date
    Sep 2014
    Posts
    1
    new town nd
    john deer
    Looking for the oil plug thread size for 430e or 420e Cat Backhoe.
  6. #6
    Platinum Member DennisArrow's Avatar
    Join Date
    Jul 2003
    Posts
    766
    Sugar Valley, Ga
    Iseki TL 2300, Kubota RTV, Kubota B7610
    Quote Originally Posted by phillipb View Post
    uhhh.....you might try the cat forum or maybe a mod will do something..........God bless.........Dennis
  7. #7
    Gold Member Teikas Dad's Avatar
    Join Date
    Aug 2012
    Posts
    367
    Live Free or Die
    Kubota B3200
    By any chance would the M12X1.25 be the same size for a B3200?
    2012 Kubota B3200 FEL/BH w thumb R4
Similar Threads
  1. Caroni Flail Belt Failure
    By sunspot in forum Attachments
    Last Post: 06-27-2016, 08:27 PM
  2. Replies: 26
    Last Post: 01-20-2013, 04:39 AM
  3. Briggs 11 HP oil seal con
    By Craig Clayton in forum Parts/Repairs
    Last Post: 05-02-2010, 10:01 PM
  4. Swivel Housing Seal, Leaking on a 1533 @ 300hrs.
    By MrSteve in forum Massey Ferguson Owning/Operating
    Last Post: 09-19-2008, 08:22 AM
  5. I have two different size front wheel/tires . . .
    By mark.r in forum Kioti Owning/Operating
    Last Post: 08-28-2008, 11:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
