Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
  1. #11
    Super Member CompactTractorFan's Avatar
    Join Date
    Jul 2010
    Posts
    7,963
    Pennsylvania
    Kubota BX25
    Default Re: Leaking Hydraulic Line - Same Repair 3 Times
    Quote Originally Posted by rdsaustintx View Post
    Be careful around small leaks. It's rare, but if you get hit with a micro-stream of hydraulic fluid, it can cause a gangrenous wound.
    I think this calls for that picture that has been posted on here before...
    Kyle - CompactTractorFan
    Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
    2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
  2. #12
    Elite Member
    Join Date
    Sep 2003
    Posts
    4,160
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
    It sounds like vibration cracking, common on steel hardlines. May need some rubber blocks added?
  3. #13
    Join Date
    Sep 2008
    Posts
    201
    Ontario and Quebec
    B26, G11000 generator and a G1800
    I'm not familiar with your tractor model but I have worked extensively with hydraulics. You may be getting harmonic vibrations and if that's the case the lines will start vibrating more and more until something fails due to stress fractures. One way to get around that is to either, as suggested above, change your RPMs or perhaps clamp the line somewhere with a rubber damper. The damper will change the vibrations in the line which hopefully will solve the problem. If you can't clamp the line, try cutting an old inner tube into a strip and either hose clamp, tie wrap or use electical tape to tape the rubber to the line near where it's failing. It's a cheap try and shouldn't effect your warranty.
    I agree, three replacement lines seems like a bit much. One bad original line and maybe another bad replacement but not a total of four lines. kubota seems to be trying to fix a symptom and not the root cause.
    Micro hydraulic leaks are very dangerous. You may not see the very fine stream of hydraulic fluid jetting out but it can go right through your skin. In fact medical injections were once, and may still be done using the same principle. Never ever leave you hand, even when gloved, on a hydraulic line.
  4. #14
    New Member
    Join Date
    Feb 2011
    Posts
    12
    western, NY
    Kubota B26 / Kubota L3830
    I don't think he ran the tractor long enough to have a new line crack from vibration. I would want to know exactly where it was leaking. You can use a piece of paper to find where it is spraying from. It could be a bad flare on the fitting or (I am not sure how the fitting is in the tractor) maybe the housing is cracked where the fitting is threaded into it......Jim.
  5. #15
    New Member
    Join Date
    Feb 2011
    Posts
    21
    Nova Scotia, Canada
    Kubota BX2360
    Thank-you all....I appreciate your feedback. I have the tractor back now, and working fine as you might suspect. If I were a betting man, I'd put money on the line leaking again soon though.
    The dealer tells me that replacing the steel line is the only thing he can do since this is the "kubota authorized repair". He suspects that Kubota will come up with a proper fix soon.
    I've had some good feedback here. Sounds like it's one of three things:
    1. Hydraulic Pressure
    2. Vibration (and lack of rubber blocking)
    3. A faulty male end to the JIC fitting...which is causing the female end on the line to fail.
    My money is on #3. The next time this fails, I'm going to contact the Kubota Rep. The dealer has agreed that this problem will be resolved regardless of the warranty period now.
    This continues to be frustrating, but at least everything is covered under warranty.
  6. #16
    New Member
    Join Date
    Feb 2011
    Posts
    12
    western, NY
    If the fitting itself is is bad (the male JIC flare), it should be an easy, cheap fix to change it or put a flare saver on it. ....
  7. #17
    Join Date
    May 2009
    Posts
    803
    Maine
    International 2544 / Gator 825i
    Quote Originally Posted by cboudreau View Post
    I understand your frustration the BX 1860 is heading back to the dealer for the same repair for time number 4....it sucks. So many people have no problems at all but it seems like the lucky ones get tractors that can't stay out of the shop. The metal hydraulic line has been the only breakdown but when it breaks everytime you go to use it you might as well not have the tractor. Not even 2 yrs old having that line replaced 4 times is insane, my 70's something International just keeps going and going...pretty sad when I have to keep using it for everything because the new Kubota is broken.
    The last time the dealer had it they replaced the line and the male fitting....no dice it's something else causing it.
  8. #18
    New Member
    Join Date
    Feb 2011
    Posts
    12
    western, NY
    I would try and put a hose on it and see if that works. It may be they have a bad batch of lines or tubing?
  9. #19
    New Member
    Join Date
    May 2010
    Posts
    16
    Is this the location of the leak?
    Leaking Hydraulic Line - Same Repair 3 Times-bx-jpg
  10. #20
    Join Date
    May 2009
    Posts
    803
    Maine
    Quote Originally Posted by lakeridge View Post
    This is the exact line that is cracking on the 1860....does this have a Technical Service Bulletin number or anything I could give to the service department to aid in the repair? It's back at the dealer right now for the fourth line replacement.
Similar Threads
  1. JD2320 Leaking fluid around the 4 hydraulic quick-connects...
    By bill1369 in forum John Deere Owning/Operating
    Last Post: 02-07-2011, 12:01 PM
  2. Leaking water line
    By coffeeman in forum Related Topics
    Last Post: 12-18-2010, 02:13 PM
  3. Leaking Steel Line
    By F350 in forum Parts/Repairs
    Last Post: 06-12-2010, 08:28 PM
  4. FEL Hydraulic Control 3rd Line connection??
    By deepNdirt in forum Hydraulics
    Last Post: 09-22-2009, 07:27 PM
  5. How do you not pop your hydraulic line?
    By txdon in forum Hydraulics
    Last Post: 02-03-2005, 09:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
