Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
  1. #1
    Member
    Join Date
    Jan 2011
    Posts
    27
    Default Just installed WR Long 3rd function
    I just finished installing my 3rd function kit from wr long last night on my B3300. I shopped around and found Iowa Farm Equip. to be the cheapest place to order from. It showed up in 2 days.
    I must say, I am very pleased with the overall function of the kit. It comes complete with everything you need, if you do not have a backhoe. Because I have a backhoe, I had to add in my hydraulic loop for that, but had to purchase one fitting. Very simple to do. The hardest part of the installation was taking off my loaded tire! lol
    For all of those contemplating which route to take in adding a 3rd function to control a grapple or front attachment, I believe this is the only way to go. This kit from WR Long is complete with specific hardware for your model. If you are mechanically inclined and understand how these things work, you can purchase this valve and make you own kit for less money.
    Next week I will be installing one on my nieghbors JD3320.
    Hope this helped some.
  2. #2
    Elite Member Ductape's Avatar
    Join Date
    Feb 2006
    Posts
    4,856
    Central New Hampshire
    Kubota B3030HSDC
    Default Re: Just installed WR Long 3rd function
    Nice work............................. now post us some pictures or we won't believe you !
  3. #3
    Member
    Join Date
    Jan 2011
    Posts
    27
    Here are a couple pics.
    Attached Thumbnails Attached Thumbnails Just installed WR Long 3rd function-wr-long-kit-install-007-a   Just installed WR Long 3rd function-wr-long-kit-install-011-a   Just installed WR Long 3rd function-wr-long-kit-install-012-a
  4. #4
    Join Date
    Feb 2010
    Posts
    157
    South Central PA
    Kubota Grand L3540
    Nice work! The more I read about these kits the more I want one...
    Kubota Grand L3540 HSTC-3
    LA 724 Loader/72" HD quick attach bucket
    Woods PRD7200 RFM
    Woods GB72 Box Blade
    Woods HBL96 Rear Blade
    Woods LR72 Landscape Rake
  5. #5
    Silver Member Tachdriver's Avatar
    Join Date
    Nov 2010
    Posts
    203
    Kubota bx25
    I like it ! Very nice kit and good work there.
    later
    2011 model Kubota BX25 machine, Custom front hitch, 5000# Winch, Horn, Front tow hook, Thumb, FEL tooth bar, rear wheel spacers, DIY forks for the FEL, Rear skid plate, Homemade Ripper tooth, DUBBS technologies Light bar, Pats easy change system, Custom Toolbox on back of seat, Canopy, Country line Subsoiler, Homemade boompole, Kubota Arm rests, Fire Extinguisher bracket, Oil pressure Gauge, Temperature Gauge, Voltmeter, Home made PECS stabilizer bar and 4 foot United Box Grader.
  6. #6
    Join Date
    Feb 2006
    Posts
    4,856
    Kubota B3030HSDC
    Nice clean install.
    Have you got a grapple already?
  7. #7
    Join Date
    Oct 2004
    Posts
    87
    Eastern, NC
    Glad to hear you are happy with your valve kit. There is a flow diagram on our website that might be an additional help in the future.
    http://www.wrlonginc.com/Hyd%20DO3B%...%20Diagram.pdf
    Thanks,
    Nelson
  8. #8
    Platinum Member westbrooklawn's Avatar
    Join Date
    Apr 2005
    Posts
    648
    North Carolina
    kubota L3400HST
    Neslon - great reference diagram. Not to hijack this thread, but I have your valve installed on my L3400 to control my grapple and love it. I want to put rear remotes on the tractor, but hadn't figured it out yet. From your diagram it looks like I would simply run the T hose from your valve to the back of the tractor to the new remote valves, and then run from the remote valves back to where the T hose is currently attached (or to the tank filler port at the back of the tractor)... is this correct?
    L3400HST, L463 FEL, Markham toothbar, Markham Grapple, Woods BH80-X, 5 1/2' United box blade,6' Leinbach scrape blade, Pallet forks, 5' King Kutter RM, 56" First choice tiller, Leinbach rake
  9. #9
    Join Date
    Oct 2004
    Posts
    87
    Eastern, NC
    The power beyond port is used to power other devices on your tractor like our 3rd function valve kit, a backhoe, remotes, 3 point hitch and so on. Each time you add one of these devices you introduce some pressure losses and temperature increases, however normally they are slight changes. If you chose to add another device to your system you would need to make sure that anything you added was after your loader valve and that it was inline. There are no Tee's in an open center system, everything is in series. You could disconnect the hose from the T port on my valve an connect it to the outlet of your remotes and make a new hose to connect from the T port on my valve to the inlet of your remote.
    Nelson
    Quote Originally Posted by westbrooklawn View Post
  10. #10
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,713
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    Just for the record, I ordered my 64" grapple and 3rd function valve from Nelson last week. I was very happy with his customer service. I can't wait to get the parts installed. Thanks for sharing your pics, I am really looking forward to playing with the grapple when the snow melts.
Similar Threads
  1. WR Long electrohydro valve??
    By jgrreed in forum Hydraulics
    Last Post: 12-09-2008, 06:57 PM
  2. WR Long Inc 3rd valve
    By Marek in forum Kubota Owning/Operating
    Last Post: 12-05-2008, 10:28 AM
  3. DIVERTER vs 3RD FUNCTION VALVE
    By flINTLOCK in forum New Holland Owning/Operating
    Last Post: 03-29-2007, 01:02 PM
  4. 3RD function FEL
    By flINTLOCK in forum Owning/Operating
    Last Post: 03-01-2007, 11:39 AM
  5. wr long online source
    By wickedinhere in forum Attachments
    Last Post: 09-26-2006, 10:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
