Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Bronze Member twinsticks's Avatar
    Join Date
    Oct 2005
    Posts
    82
    NJ
    2005 BX 23
    Default Bx 23 front axle leaking oil
    Anyone ever had this problem bx 23 has 260 easy hours .. What is involved with fixing it .. It has to be a seal leaking..
    Attached Thumbnails Attached Thumbnails Bx 23 front axle leaking oil-image-1124779933-jpg   Bx 23 front axle leaking oil-image-3542705213-jpg   Bx 23 front axle leaking oil-image-45484218-png
  2. #2
    Join Date
    May 2000
    Posts
    243
    WHITE MNTS. NH
    KUBOTA BX2200 & L-39 TLB
    Default Re: Bx 23 front axle leaking oil
    twinsticks:
    Do a search for this issue, and you will find numerous posts.
    I have a BX2200 with likely the same axle set-up, and had the same leak.
    Before taking things apart, kubota reccomends if you are using SUDT fluid, to change to 80-90w gear oil, and see if that stops the leak.
    I believe that an "o" ring seals the lower axle pivot point, which appears to be the source of the leak.
    Another case of an inexpensive part (O ring) but an semi-expensive repair due to the labor involved to change it.
    Good Luck:
    WALT
  3. #3
    Join Date
    May 2009
    Posts
    77
    Northern Ohio
    06 BX 23, AC Little G, JD 322
    Or it could have a crack like I had in both of mine. First attempt was o-ring and when that didn't work they pulled them apart and really checked it out and found them both were cracked.
  4. #4
    Elite Member
    Join Date
    Oct 2004
    Posts
    2,952
    limerick pa lycoming county pa
    kubota bx23
    I have the same leak when I lifter the front end up and felt the joint there was more slop in the leaker than the other side.
    I will be switching to 90 wt as soon as I get a chance.
    In the summer I will be tearing it down to replace the seal.
    tom
    If it ain't broke we will help you brake it
    If it is broke we will help you get it fixed!
    https://www.facebook.com/joseph.t.mussington
  5. #5
    Join Date
    Sep 2005
    Posts
    139
    new brunswick canada
    bx 1830 05
    Quote Originally Posted by rlsmith View Post
    they are all the same mine did that too change the 2 seal
  6. #6
    Join Date
    Oct 2005
    Posts
    82
    NJ
    2005 BX 23
    Okay I will try gear oil, what which brand would you use.
  7. #7
    Join Date
    May 2000
    Posts
    243
    WHITE MNTS. NH
    twinsticks:
    I used whatever Tractor Supply had in the 1 QT. bottle. It may have been Valvoline 80-90w.
    I don't think kubota spec'd a certain brand.
    The front axle is similar to a attachment gear box, in that the oil selected is not as critical as a motor oil or hydraulic fluid would be, to my way of thinking.
    Let the opposing opinions commence.
    WALT
  8. #8
    Join Date
    Feb 2005
    Posts
    626
    Southern Indiana
    BX23
    If mine were leaking that bad, I would put 140 Wt. in it, park it on card board to keep the oil off of the floor, and just keep it checked and full.
    ron
    I was better, but I got over it.
    Life may change us, but we start and end with family.
  9. #9
    Veteran Member kevinj's Avatar
    Join Date
    Jul 2003
    Posts
    1,382
    West MI
    BX-1860, L3940HSTC, B7500, Farmall M, Farmall 560D
    Quote Originally Posted by 638 View Post
    If mine were leaking like that I would put a seal in it and be done with it! I done my B and it is not much of a job, less than $50.00
    It may also be cracked as noted above, in that case I would want it replaced so I did not have failure later on.
    Kevin
    BX1860, mower, snowblower - B7500HST, FEL, Bush Hog - Grand L3940 HSTC, FEL, snowblower, 6' Landpride brush hog, 6' King Kutter tiller, Corn Pro 18+5 Fifth Wheel, 1950 Farmall M, Farmall 560D
  10. #10
    Veteran Member Wacky's Avatar
    Join Date
    Apr 2010
    Posts
    1,115
    West Virginia
    2010 GC2610
    One thing to remember, if you are not going to change the seal, if oil can leak out, water will get in.
    2010 MF GC2610--MF60"MMM--King Kutter XB 4' rotary cutter-- 4' King Kutter XB boxblade-- Ratchet Rake-- Check that parking brake
Similar Threads
  1. Are we running out of fossil fuels? - peak oil theory
    By hazmat in forum Related Topics
    Last Post: 03-15-2011, 02:39 AM
  2. B7100 front axle leak. Oil type?
    By Illini22 in forum Kubota Owning/Operating
    Last Post: 08-17-2010, 12:46 PM
  3. Oil & Fuel 2305 Front axle oil
    By fdmars in forum John Deere Owning/Operating
    Last Post: 05-25-2010, 04:04 PM
  4. Oil & Fuel oil capacity in dk 35 front axle ?
    By n1wjr in forum Kioti Owning/Operating
    Last Post: 04-11-2007, 08:24 PM
  5. What gives with my front axles
    By 4710and110TLB in forum John Deere Owning/Operating
    Last Post: 07-22-2004, 12:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
