BX 2200 Cheap Cab
   / BX 2200 Cheap Cab #1
NY_Yankees_Fan
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
I installed a golf cart cover on my BX 2200 yesterday, this is the finished product, rear view. Total cost $125.00. Not tested yet, waiting for snow, but I think it will keep the snow off me.
   / BX 2200 Cheap Cab
This is the frame I made up with some ¾ inch copper tubing. I put a ½ “ plywood top on the ROPS and secured it with 2 – ¼ bolts to a rear light bracket. In the front I attached it to the tubing with 2 –1/4 bolts. I did not want to drill any holes in the tractor. This is a front view before the cover was added.
   / BX 2200 Cheap Cab
This is the right side of the cooper-tubing frame. On the FEL Kubota has cut a hole in the bracket. I put a large washed and a ¼ “ bolt with a nut trough the hole to hold the cooper tubing onto the tractor.
   / BX 2200 Cheap Cab
This is the other side, I just used plastic tie wrap to hold the copper tubing in place.
   / BX 2200 Cheap Cab
This is a close up of the roof. I added a plastic cover to protect the sharp plywood edge from cutting the vinyl cover. I picked the plastic cover up at my local Ace Hardware store. It is one inch tubing that is cut on one side to bundle wires. It worked great, I just pushed it on and it stayed in place.
   / BX 2200 Cheap Cab
I did not want to cut the cover, and it is too long, so I used paper clips to hold the rolled up plastic to the edge of the frame. They look like they may hold OK, any other suggestions to secure the vinyl?. I have to relocate the lights to the outside of the cover. I was thinking the best way would was to burn a hole through the plastic instead of cutting it? I was going to heat up a piece of copper tubing and then push it trough the vinyl, think that will work?
Regards
Tom
   / BX 2200 Cheap Cab #8
Looks like it will keep the snow off you.Don't know about making a hole in the plastic with a piece of hot copper pipe,but if I was to do it that way have a wet rag close by so it won't burn more than what you want.May look ulgy where the burn holes are too.Too bad to make a mess of a good looking project.Alot cheaper than $1900.Was surprize to see your blower green.Mine is red.I guess they paint them any color,like many companies do.I took my blower off again.I'm hauling some wood with my cheap Wal-Mart trailer.Suppose to snow Christmas day.Merry Christmas to you and your family.
   / BX 2200 Cheap Cab #9
Looks good to me,and I hope it keeps the breeze off your knees,and the snow off your back. /w3tcompact/icons/wink.gif
   / BX 2200 Cheap Cab #10
Hi,A bolt hole punch from a gasget making set should work fine.You can get the punches in many sizes.
UNUSED X-STAR 101" X 20' LOADING RAMP (A58375)
UNUSED X-STAR 101"...
8 Piece Excavator Heavy Duty Attachment Set (New/Unused) To Fit CAT 301 (A59225)
8 Piece Excavator...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
(40) Collectible Watches in Box (A57453)
(40) Collectible...
Onsite begins 8:30am / Online begins 9:30am (A57149)
Onsite begins...
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
