Results 1 to 10 of 27
03-20-2011, 07:48 PM #1
Log splitter question ?
I have a B7500 and would like to purchase a 3ph log splitter . Is it possible to run the log splitter off the valve block for the FEL ( with the FEL hose disconnected ) and use the FEL control arm to run the splitter ? Or do you need to plumb for a rear remote with a single acting valve ?
ThanksB7500 FEL / 54 " Mower
60" woods rear blade
62" bushog RTS tiller
Countryline Sub Soiler
Simplicity Broadmoor
Cub Cadet 1812
03-20-2011 07:48 PM # ADS
03-20-2011, 08:21 PM #2Silver Member
- Join Date
- May 2010
- Posts
- 150
- Location
- North Central Ct
- Tractor
- Kubota Cab L3940, FEL 724 QA, BH92
Re: Log splitter question ?
You could probably due either. The issue is the flow rate through that system to the splitter will be okay but not great. It will cycle considerably slower than a normal splitter. You can get a PTO hydraulic pump to compensate but then you are talking quite a bit more money. How many cords do you plan to split? I have had a PTO splitter and several independently powered ones and would not do the PTO rig for more than 2 or 3 cords a year. Above that I would be getting an independent rig.
Life's to short not to own a tractor
Kubota L3940 HSTC-3
723 FEL QA, R4's, BH92 18" and 12" buckets
Land Pride tiller, Sitrix Spreader
Land Pride Grader blade, York Rake
B74 Blizzard 3pt blower, HD Country line PHD
3pt Bale Spear, Middle Buster, more misc.
03-20-2011, 08:53 PM #3
I only split 1 to 2 cords a year . I am ok with it being slow just wasn't sure if it was possible to run off the FEL valve block . If I had to install rear remotes I think it would be a better buy to purchase a stand alone unit .
thanksB7500 FEL / 54 " Mower
Cub Cadet 1812
03-20-2011, 09:33 PM #4
One to two cords per year.....thats maul work if you can physically do it!
Don't waste your money, those 3pt units are junk in my opinion!
CraigHonda is truly the best on earth, but Kubota is coming a close second!
Remember - you get the government you deserve and voted for!!
OBAMA - One Big Ass Mistake America
03-20-2011, 09:44 PM #5Silver Member
- Join Date
- May 2010
- Posts
- 150
- Location
- North Central Ct
- Tractor
The pump of the FEL will be not make it worth your trouble for the fittings, valves and lines. Renting a unit for that amount would make more sense to me. You would be easily be into the whole rig for 800.00 to a grand by the time it is all said and done if you include the cost of a splitter. A 50.00 to 100.00 rental fee each year to rent a splitter would make more sense to me. It would take you 10 to 15 years at that rate to break even relatively speaking.
Kubota L3940 HSTC-3
03-20-2011, 10:05 PM #6
Best option would be to run a power beyond loop to the rear of the tractor to power the splitter. It's the same you would do to power a backhoe. It would be possible to power a splitter off of your loader valve, but you'd have to bungee, or otherwise hold the valve open to send hydraulic pressure to the splitter valve....... just not the best option.
03-20-2011, 10:44 PM #7Bronze Member
- Join Date
- Jun 2008
- Posts
- 89
- Location
- Canada
- Tractor
- BX2660
We shouldn't discourage anyone from buying equipment that they may not be able to justify...that is his wife's job.
For hydraulic connection questions you should talk to Supermember kennyd. He got me pointed in the right direction. For a splitter, check out the Split-fire splitters. They have are dual action for splitting twice as quickly/efficiently. I generally do a cord per hour with a helper.
03-20-2011, 10:46 PM #8
Thanks for the tips . After a weekend of splitting wood and a sore shoulder I figured I wood
ask .
I think I will keep my wedges and splitting maul sharp
Cub Cadet 1812
03-20-2011, 10:51 PM #9
i love my wood splitter. built it myself for a couple of hundred bucks. i installed a power beyond system on the tractor for other reasons though. i wanted a hydraulic swivel for my snowblower.
that was a must . so, since i had the remote in the back, why not a wood splitter. its so much nicer to split wood when i want to, not when i have to to get the unit back to the rental yard. i hate splitting wood, but this makes it bearable.
as far as using the FEL levers to run the splitter? im confused. you need a control lever down at the area your working. not up by the seat. personally id add the power beyond/rear remotes. youll thank me later.
i can split wood faster than the wife can get it stacked. so just because some people think there too slow, it all depends on how truly lazy you want to be.
currently own
2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
Quick Attach 79" loader mount snowblower & rear powerpack
Quick Attach 84" Snow Blade
Quick Attach 42" pallet forks
03-21-2011, 07:56 AM #10Veteran Member
- Join Date
- May 2007
- Posts
- 1,018
- Location
- MO
- Tractor
- John Deere 790, 420, 314, 317 "Special", "L/60" Custom & 70 I
My splitter is similar to grsthegreat's, originally built it for my JD 520 for $200. When I added the new hoses & control valve to use it on my JD 790, I spent another couple hundred. Can't get the power beyond kit anymore, so I just use long hoses & hook the the loader bucket connections, tie off the joy stick & use the control valve on the splitter. Slow, yes, but so am I!
I'm not in any big hurry & work by myself anyway. ~~ grnspot
Similar Threads
Log splitter
By sly601 in forum HydraulicsReplies: 9Last Post: 03-27-2012, 11:42 AM -
Log Splitter Question
By bstnh1 in forum AttachmentsReplies: 17Last Post: 08-27-2010, 04:53 PM -
3 point log splitter
By sherpa in forum HydraulicsReplies: 35Last Post: 11-10-2009, 09:16 AM -
Log Splitter Engines Recalled By American Honda Motor Co. Due to Fire Hazard
By shimp in forum SafetyReplies: 6Last Post: 07-21-2008, 06:01 PM -
3Pt Log Splitter Hydraulics Question
By centex in forum AttachmentsReplies: 4Last Post: 12-06-2006, 05:26 PM
