American Solutions Grapple BX2660 install
   / American Solutions Grapple BX2660 install #1
mjribeiro
Member
Hunterdon County NJ
Kubota BX2660
I know this one has been done, but here is one more. I'm super happy with the heavy duty construction of this unit, and Jeff is great to work with.
Mark the location for the bucket brackets. Use a framing square and the measurements in the instructions. If these brackets are crooked, you will have a hard time later with the quick disconnect pins.
Clamp the brackets securely.
Use a 1/2" drill bit to mark the holes.
Then a smaller bit as a pilot, then finish with the 1/2"
There are three holes, but you will only use two. Use the bottom one, and either of the top that will not interfere with the top of the bucket. On a newer LA243 FEL, it's the very top hole.
Next I attached the diverter valves. When you order one of these make sure you tell Jeff the size of the cross brace on your FEL. Older BXs are larger than the newer ones and you need the correct size clamps.
Next come the lines. You detach the flex lines right where they connect to the hard lines. The stock flex lines go into the diverter valves, the short ones from the valve go to the hard lines.
Long ones go to the bulkhead fitting. Mount this bracket on the back of the bucket in a spot that gives the lines the most range of motion and protection.
The switch can go anywhere, I chose the left floor board.
The harness come with blade connections which you would position near the hose disconnects.
Some guys swap that out with a twist plug. I'm a fan of the powerlet connectors.
With the plug out.
Mount the grapple to the bucket brackets, tighten the adjuster nuts, install the quick disconnect pins. (How parallel are your bucket brackets??? You will find out here!)
Attach the quick disconnect lines and you are in business!
Me want cookies! Er, I mean, let me go do some serious work cleaning out brush.
It really was not hard to install. It could be done in a couple of hours, 3-4 if you are taking your time.
   / American Solutions Grapple BX2660 install #6
Great job. Now I just need to take my computer to my workshop to follow directions,:thumbsup:
   / American Solutions Grapple BX2660 install #7
looks awesome! those teeth looks impressive!
   / American Solutions Grapple BX2660 install #8
Very nice job. You are now ready for toe to toe combat with Mother Nature. Grapple plus bush hog is a great combination for medium sized brush. You'll need something like that on the rear for ballast anyways.
   / American Solutions Grapple BX2660 install #9
Very nice job indeed.:thumbsup:
   / American Solutions Grapple BX2660 install #10
During the last couple of years, several TBN members reported attempting to contact American Solutions and getting no response. Then someone at AmSol posted on here that they were up and running again. Sounds like the business was sold or the owners went through a family crisis for awhile. Could you please report how your communication with them, pricing, ordering process, wait time, delivery, etc. went, so that others will be up to date on the status of things?
BTW, for those shopping for a BX FEL grapple, there are a number of threads in the archives. Also, Gearmore sells an almost identical model.
Thanks.
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
