ericdube
Gold Member
I'm looking to build a hydraulic pressure tester for my B2620 tractor, and I was wondering if I might be able to get some advice on the correct components to use.
I'm not sure exactly what the QD fittings are, but I believe they're the same as on the BX-series 1/4" - it looks like Snap-Tite 72N4-4F (Nipple) and 72C4-4F (Coupler) should be a match. Can anyone verify this?
Here's a complete list of components that I'm looking to use in order to build it:
This would be a flow-through design (in-out) using a tee fitting to connect the pressure gauge.
In addition, does anyone know what the recommended hydraulic pressure setting is for the B2620 tractors?
Thanks in advance for the help!
- Snap-Tite 72N4-4F
- Snap-Tite 72C4-4F
- Parker 4-4-4 MT-SS 316 Stainless Steel Pipe Fitting, Tee NPT 1/4" Male X 1/4" Male
- Parker 4-4 FHC-SS 316 Stainless Steel Pipe Fittings Female Hex Coupler 1/4"
- Valley Instrument 2 1/2" Stainless Steel Glycerin Gauge 0-3000 PSI
