Page 2 of 7 FirstFirst 12345 ... LastLast
Results 11 to 20 of 61
  1. #11
    Gold Member paulwestski's Avatar
    Join Date
    Mar 2011
    Posts
    326
    VA Beach & Amherst, VA
    Kubota L4240
    Default Re: Top & Tilt and Rear Remotes Installed
    Quote Originally Posted by PHILIP8N View Post
    Where did you get your hydraulic quick connect rubber protector caps at? I really like those. The oem ones for my fel keep falling off. Those look really nice. Thanks. Philip.
    I got them off of Ebay. They don't fit the female QC very well at all. They fit the male QC just fine. I've 3/8" QC's and that's what the dust caps are.
    They just don't engage the ball bearings in the QC tight enough. You can push them in and pull them right out of the female QC. My factory ones you must pull back on the QC sleeve to put on and remove. The guy I bought them from said I could exchange them for 1/2" dust caps but that probably won't fit.
    Kubota L4240 HST+ R-4's,
  2. #12
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,412
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Paul, a little off the subject, but is the dozer in your avatar yours also?
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  3. #13
    Join Date
    Mar 2011
    Posts
    326
    Kubota L4240
    Quote Originally Posted by MtnViewRanch View Post
    No that was a rental I used when I was clearing the property. I also used it to move my 8' x 20' shipping container up the logging road and then my access road to set it on my property. It also was handy to tow my 30' camper up to the property. I unbolted one of the loader bucket teeth and bolted a 2" receiver hitch to the bucket. It was slow going but I was able to park the camper exactly where I wanted it. My 1 ton SUV could have towed it up the mountain but parking it exactly where I wanted to might have been another thing.
    Attached Thumbnails Attached Thumbnails Top & Tilt and Rear Remotes Installed-img_3670-jpg   Top & Tilt and Rear Remotes Installed-img_3669-jpg   Top & Tilt and Rear Remotes Installed-3-22-11_0002-jpg
  4. #14
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    9,412
    Picture 3 is pretty impressive.
    Brian
  5. #15
    Join Date
    Mar 2011
    Posts
    326
    Kubota L4240
    We used to move loaded containers from the side the same way with big rough terrain forklifts. Just fork it from the side and run two chains to the top corners on the same side. Just make sure you're using 3/8" chains or larger.
  6. #16
    Join Date
    Mar 2011
    Posts
    326
    Kubota L4240
    Here's the original thread
    http://www.tractorbynet.com/forums/o...ml#post2321209
  7. #17
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,598
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    Discount Hydraulic Hose carries those. I have standard AG connectors and they fit fine. Both male and female.
    Very nice work Paul
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  8. #18
    Platinum Member thavil's Avatar
    Join Date
    Jul 2008
    Posts
    742
    Southern Maryland
    Kubota BX24
    Awesome fabrication paulwestski!! I wish I had your skills.
    BX24, 60" MMM, Woods HC48 Rotary Cutter, W.R Long Flat Toothbar, 4' Farm Force Box Blade, Leinbach 7200JR PHD w/ 12" & 9" augers, Cosmo XB 3PH spreader, Pat's Easy Change, Front & Rear Bro-Tek Skid Plates, BXpanded Under Armor/Brush Forks/BH Dolly/Bucket Hooks/Tool Pouch/Work Lights, drag harrow, Larry's Mower Axle Stands, 52" Rachet Rake, Millcreek manure spreader
  9. #19
    Join Date
    Mar 2011
    Posts
    326
    Kubota L4240
    Quote Originally Posted by thavil View Post
    Thanks for the compliment Thavil
  10. #20
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,713
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    Paul,
    Thanks for posting the pics and details of where you mounted the valve. I am ordering that same 4 spool wolverine valve from Surplus as well. I'm not really sure where to mount it yet and I never thought of mounting it where you did. How do you like it now that it's been on there a few weeks? Is it easy to control the top n tilt while looking back at the implement? I may end up mounting it in the same spot on my L4610. I was also thinking of mounting it on the right side fender somehow or attaching some angle iron to span the ROPS in the back and attach it to there. Any other suggestions or opinions on that?
    Also, if you could mount it in the back near the top n tilt in an out of the way location, can you just directly plum the hydraulic lines into the valve? Rather than using the rear bracket setup like you have (although I realize this wouldn't look factory by any means)
    Thanks again and great job on the fabrication.
Similar Threads
  1. Help setting up a top and tilt on a TC40-S
    By nickel plate in forum New Holland Owning/Operating
    Last Post: 11-21-2010, 06:57 PM
  2. Rear Blade Rear Blade, Hydraulic Tilt or Hydraulic Offset (only one rear remote)
    By CowwFace in forum Attachments
    Last Post: 09-14-2009, 06:58 PM
  3. Valve connected to rear remotes?
    By anojones in forum Hydraulics
    Last Post: 08-27-2009, 09:25 AM
  4. Top, tilt , I match
    By MACDABS in forum John Deere Buying/Pricing
    Last Post: 12-25-2007, 08:57 PM
  5. Power Beyond vs. Dual remotes vs Top 'n Tilt, etc?
    By picker77 in forum John Deere Buying/Pricing
    Last Post: 02-26-2006, 06:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
