Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 61
  1. #31
    Gold Member paulwestski's Avatar
    Join Date
    Mar 2011
    Posts
    326
    VA Beach & Amherst, VA
    Kubota L4240
    Default Re: Top & Tilt and Rear Remotes Installed
    [QUOTE=Chilly807;2414976]
    Quote Originally Posted by paulwestski View Post
    Sounds like an expensive three-peckered octopus to me...
    Sean
    Actually that would be four peckered....it's a four spool valve.
    Sure will make life easier...rather than letting the last adjustment on that box blade be good enough. I can make it exactly how I want it without climbing up and down continually. I work my tractor in mountain terrain. If you want to create a level area and the the tractors leaning on a slope and you have the three point angled to one side you can only make cutting passes in one direction. With the hydraulic TnT you can make a pass in one direction then turn around tilt the opposite and make another pass...all from the comfort of of your seat.
    Too bad all tractors don't have the TnT as standard equipment.
    Good thing my hobby is tinkering and upgrading
    Kubota L4240 HST+ R-4's,
  2. #32
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,719
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    How many GPM does your hydraulic pump put out?
    Your valve should rated slightly higher than your hydraulic pump output.
    It's 9.6gpm for implements....
    Do you have a welder?
    If so you can build the valve mount that u-bolts to the ROPS yourself.
    I do, so I'll attempt to build something for the bracket.
    One thing to visualize is on that four spool valve you'll have ten hydraulic lines coming off of it.
    Ya when you say it like that it does seem to make that little ole valve a whole lot bigger
    What were you going to use the other two valves for??
    Well I want to use one for the log splitter which will have the PB sleeve in it, and I really don't have any use for the other. I'm thinking that once I get a box blade I may spring for hydraulic scarifiers, but most likely not. I really don't have any use for the 4th spool right now.
    I'll have to find out some more about the float valves because I will want the ability to use the float, so if the valve I was going to order doesn't offer it I want to find something that does. Thanks again for all your help.
    I'll start doing some more reading on what valves will and will not work with the setup I want.
  3. #33
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    Quote Originally Posted by Piston View Post
    Unless I'm mistaken, the power beyond sleeve will go in the outlet port of the valve body, to carry fluid to the next valve body in circuit, usually the 3ph control valve. I'm assuming you're going to run the power beyond hose from the loader valve to the new valve inlet port, and the return line to tank from the new valve can be teed into another tank line, usually the one from the loader as well. The remaining two unused spools will be blanked for now until you have a use for them?
    Sean
  4. #34
    Join Date
    Mar 2011
    Posts
    326
    Kubota L4240
    Quote Originally Posted by Chilly807 View Post
    Sean
    Sean
    you're correct..three lines from the new spool valve not including the remotes.
    High pressure in, from the loader power beyond
    High pressure out, to the line that was connected to the loader power beyond.
    Return line out, usually "T's" into the loader return
  5. #35
    Join Date
    Mar 2011
    Posts
    326
    Kubota L4240
    Anyone getting ready to order a T&T for your Kubota L3400 or L2800??
    When I ordered my T&T kit I thought that I was getting a L3400 and then Brady Barlow upgraded me to a L3800.
    According to Brian at FitRite my tilt cylinder is too long.
    The top cylinder is the right length.
    I was hoping to trade cylinders with someone that is getting ready to order a T&T set up from FitRite for their L2800/L3400.
    I haven't yet had a chance to use my T&T yet. All I've been able to do is mount it, plumb it and mount the quick hitch.
    Thank the good Lord I'm so busy at work......... I cant get up to the mountain property and get any seat time in and try out the T&T.
  6. #36
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    I was under the impression that part of the L3400/L3800 was the same dimensionally? I'd try it first and be sure before you take the plunge and swap.
    Sean
  7. #37
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,473
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Sean
    OEM side links are 1 1/2" different in length with the L3400 being longer than the L3800. If you look close at Paul's pictures, you can see that the side link is more than 1/2 way collapsed and I build Fit Rite Side links to be at the mid point when the implement is level.
    Paul's current setup will work for him, it just will not have equal tilt in both directions.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  8. #38
    Join Date
    Sep 2008
    Posts
    3,719
    Lakes Region NH
    PM me if you need any advice on what fittings will work.
    Paul,
    I have a question for you about your fittings (or anyone else)
    I have ordered just about all the parts I need, and have the valve, hoses, and connections put together for the valve itself. I was waiting on a few parts that were on backorder from DHH to finish the install. I now have those parts but won't be home for another week and a half.
    I ordered a side link from Brian as well, and will be using one of my remotes for it.
    The only hoses and fittings I still need to complete the package, are the 3 going in/out of the valve, the PB, IN and OUT.
    My question is, do you remember what type and size of fittings you used to go in and out of your tractors system? I read that you used all 3/8" JIC hose ends, but I believe those are all female connections correct? So what type of adapter did you use to go from the female 3/8" JIC fitting, into your FEL pb port (or should I say out of your pb port to the hose)
    Also, what fitting did you use on the 'tractor' end of the hose going from your 'OUT" port of your valve to the hydraulic block (i guess would be return?) under your operators platform? I'm assuming I would need a male 3/8" JIC fitting (preferablly a 90*) going from the female JIC hose end into the hydraulic block?
    I will be using all 1/2" lines with the female JIC fittings on each end. I know what I need coming out of my valve, but going into the tractor is what I'm not sure of.
    I won't be back at my tractor until another week and a half and will have to start clearing property lines shortly after I get home, so I'm trying to order everything so it is at my house waiting for me when I get home.
    Thanks for your help.
  9. #39
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    Piston,
    Until Paul has a chance to reply, I'll share what I did with mine. I used mostly female JIC ends as you mentioned, and in some cases that was a mistake. The connections to my valve were ORB, so I needed to buy adapters from ORB to JIC, then screwed the hose ends to them. What I should have done was get an ORB end on one end of the hose, and a swivel JIC on the other end. The cost of the fittings are similar, but it would have saved the cost of about a dozen adapters. Only one end of the hose needs to be "adjustable" or have a swivel, plus it would have been one less chance of a leak.
    I used a 90* end teed into the return from my loader valve for the return from the remote valve, it was pretty easy to do. I learned the lesson from the female JIC ends on the valve hoses when I made up the implement hoses, there's a JIC on one end and a male NPT on the other end that goes into the male QC's. Both can move for adjustment.
    All my hoses were 3/8, as were most of the fittings. The stock hoses on my L3400 were all 3/8 so that's what I used.
    Sean
    Attached Thumbnails Attached Thumbnails Top & Tilt and Rear Remotes Installed-dsc00577-jpg   Top & Tilt and Rear Remotes Installed-dsc00578-jpg   Top & Tilt and Rear Remotes Installed-dsc00664-jpg   Top & Tilt and Rear Remotes Installed-dsc00576-jpg
  10. #40
    Join Date
    Sep 2008
    Posts
    3,719
    Lakes Region NH
    Chilly,
    THat actually helps a lot, I looked around and found some more info and also called WR Long for the size of fitting I need coming out of his 3rd function valve.
    I made my order so if I ordered the wrong stuff then it's too late
    Paul, no need to dig around looking for the answers to my confusing questions
    Thanks for posting your report and helping me along the way!
Similar Threads
  1. Help setting up a top and tilt on a TC40-S
    By nickel plate in forum New Holland Owning/Operating
    Last Post: 11-21-2010, 06:57 PM
  2. Rear Blade Rear Blade, Hydraulic Tilt or Hydraulic Offset (only one rear remote)
    By CowwFace in forum Attachments
    Last Post: 09-14-2009, 06:58 PM
  3. Valve connected to rear remotes?
    By anojones in forum Hydraulics
    Last Post: 08-27-2009, 09:25 AM
  4. Top, tilt , I match
    By MACDABS in forum John Deere Buying/Pricing
    Last Post: 12-25-2007, 08:57 PM
  5. Power Beyond vs. Dual remotes vs Top 'n Tilt, etc?
    By picker77 in forum John Deere Buying/Pricing
    Last Post: 02-26-2006, 06:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
