paulwestski
Gold Member
Piston
This is the fitting I used to "T" my return from the new spool valve back to the loader valve.
Don't worry about the "confusing" questions that's how we all learn.
I found that Surplus center has such good prices on hose assemblies (all with JIC females) that the additional cost of the JIC to ORB adapters the hoses were still cheaper than the Hydro shop. As hard as we may try to order everything just right there is always some fitting we missed. I ended up with a fairly large selection of extra fittings, hose protection, and other parts. I'll eventually use them on other projects.
If you were closer to me I'd give you a hand.
I know you're in a hurry to clear those property lines.....just take your time with the build double check and make sure everything's tight. I gets messy once you have fluid in the hoses and have to reconfigure something.
Don't for get to lube the SAE/ORB O'rings with hydro fluid before assembly.
Even the JIC fittings require a few drops of hydro fluid to provide lube while torquing them.
Did you order a set of Hydro wrenches? I'd been SOL without my set.
DON"T FORGET PICTURES AND A WRITE UP when you're done.
