Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Elite Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    4,381
    Nova Scotia
    BX 25
    Default BX25 vs B2626 with backhoe
    Been thinking about a BX.. Started a thread discussing it here http://www.tractorbynet.com/forums/k...do-bushog.htmlbut the more i read the more i wonder about a b2620. I guess this thread would be best to discuss what benefits if any for a B2620 (or a B2320) over a BX25 as it was determined in the other thread that a BX should be able to do what i want?
    First, you should know the condensed version of what its going to do:
    This machine is going to spend 90% of its life mowing lawns. Area to be mowed will be approx 2-3 acres, some with a pretty good slope.
    Other jobs planned are removing a lawn and landscaping some heavy clay soil to redirect water away from the house. Part of this will be removing about 6" of clay topsoil as the grade is too high. This will be over an area of approx 20'x60' or so
    THere will be ongoing maintenance on approx 500' of gravel drive. Including crowning.
    Also several ditches need maintaining and various french drains need o be installed.
    One last job is bush-hogging an established road and reclaiming some fields. Typically 1-2.5" dia alders.
    Can a BX do this or am i wasting my time? How are the taller B's for mowing, especially on slopes?
    The more i read, the more i think. Im second guessing myself big time. I already made one mistake, last year i bought a x540.. Great mower but i cant do the other ground engaging stuff that i hope the B or BX will do.
    I think its more the ground clearance thing weighing on my mind, mostly for the bush hogging.
    Low clearance like the BX = great for mowing.. higher clearance like the B= great for Bush hogging but not so good for mowing on slopes
  2. #2
    Join Date
    Aug 2006
    Posts
    4,381
    Nova Scotia
    BX 25
    Default Re: BX25 vs B2626 with backhoe
    A couple other questions i just thought of.
    How hard is it to remove the MMM on a BX vs a B? Is it a simple pto plug in or are belts involved? Is the deck drive over?
    Can you "lock" the MMM up on either machine and operate the rear 3pt independently?
    Oh and what about the dreaded Industrial vs turfs? Will turfs hold up for bush-hogging? Will industrials tear the lawn? The HDAP's on my 540 will pack with clay when the grass is wet and leave me stuck till i get the truck even with the x540's differential lock. It sucks sitting there with both tires spinning, but unable to get traction. One more reason i want to upgrade to a machine with 4wd.
  3. #3
    Gold Member
    Join Date
    Jul 2010
    Posts
    446
    Mapleton , Queensland , Australia
    Kubota BX2360
    Quote Originally Posted by Scooby074 View Post
    How hard is it to remove the MMM on a BX vs a B? Is it a simple pto plug in or are belts involved? Is the deck drive over? *****
    Drive over deck on B , not BX . Just a shaft twist on both and a
    pull-out lock pin on both sides.
    Can you "lock" the MMM up on either machine and operate the rear 3pt independently? *********
    YES !
    Oh and what about the dreaded Industrial vs turfs? Will turfs hold up for bush-hogging? Will industrials tear the lawn? *******
    There's not too much grip with turfs on mud or inclines , and
    they puncture easier too .
    A few answers above. The BX is way lower for Centre of
    gravity. How steep side-on are we talkin' ?
    I'm all lawns,but I often spin on an incline ; diff locks are not much use either , even on a BX , tbh .
    There are several slopes I avoid until the ground is well dry.
    You can't slash 1" to 2.5" wood with a BX and it's HP. You need a hire a guy with a proper tractor ( L/M stuff)
    for that diameter of wood. That's real brush , not overgrown grass stuff !
    BX2360 54"MMM
  4. #4
    Veteran Member JoelD's Avatar
    Join Date
    Jan 2005
    Posts
    2,005
    Windham, NH
    Kioti LK3054xs TLB, 2004
    I know you have mower but if 90% of what you do is mowing then that's what you should have for that job as a tractor will just not mow as well as a mower
    Maybe think about renting for other jobs
    Joel
    Joel
    2004 Kioti LK3054XS TLB
    Woods Box Blade
    York rake
    60 inch king kutter tiller
    - Kioti Hauler-less
  5. #5
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,640
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    bp fick has a very good thread comparing the BX and B. JOHNTHOMAS also has a lot of information. I have owned 2 BXs, but never a B.
  6. #6
    Elite Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    4,778
    Somerset, Ky
    currently own F3080 F3080 B2620 FEL/BH RTV1140
    Quote Originally Posted by TripleR View Post
    I think your questions have been answered in your previous thread and this one. You have even answered it for yourself. It's time to decide because I don't think your going to get any other answers other than the ones you've already rec'd. Maybe someone can use some different words but still same answer. GROUND CLEARANCE is biggest difference between BX and B and higher off the ground is or feels less stable. I purchase R/I4's on B's other than current B2320 has Ags (R1s) for garden work. I usually purchase turfs for BXs. I like the R/I4s and have never had a problem with them. Another decision that only you can make but I'd hesitate taking turfs into the woods or really rough areas.
    2012 B2620 FEL BH, 2010 F3080 4WD 72" Rear Discharge Deck, 2012 F3080 4WD 72" side discharge deck, 2010/2009 RTV1140CPX , RatchetRake, Forks, ...DEARBORN 2 BOTTOM PLOW 12" ?? FOR SALE $425).... Drawbar and Horse Drawn disk 11 Dodge Ram1500, 13 Ford Flex. 2009 Subaru Impreza Sport
  7. #7
    Join Date
    Apr 2008
    Posts
    567
    B2920 TLB turfs and loaded ags
    Default
    Is keeping the mower a possibility? I have a mower (ztr) and the B series and I think that is the way to go if possible . I started with a BX and I loved it but realized I just wanted a bigger tractor so I did it. When I first got my BX24 my wife assumed I was going to mow with it.
    B2920 TLB, turfs and loaded ags, thumb, 60 & 50" QA buckets, Kubota QA forks, toothbar, BX42 chipper, 60" front hydro blade and hitch, Herd M96 spreader, turf vent 48" 3pt aerator, Woods LRC 60" rake and Woods 48" estate BB, County Line 60" rear blade, rear spacers, pats easy change. Polaris 800 w/60" Blizzard plow & John Deere 717a ZTR
  8. #8
    Join Date
    Aug 2006
    Posts
    4,381
    Nova Scotia
    BX 25
    Quote Originally Posted by JOHNTHOMAS View Post
    I really hate creating multiple threads on the same issue. This one was basically to discuss the differences in the two machines. Im really second guessing myself here... I dont want to make the same mistake again... Its not that im unhappy with the x540 (im not, i love it) its just that i want something that will do everything i need. The loss im taking on the 540 is going to sting enough.,.. dont want to do this again.
    Today i went to the dealer and looked at a B2620. Its a MUCH larger machine than i thought it was relative to the BX. I Think it will be too top heavy for my slopes.. maybe im a just a chicken? Plus its taller.. not good for under low hanging branches. dealer offered me a demo of a used bx2320? but it had no mower. I passed for now
    Got some bad news while at the dealer. He had 2 Bx's with <200 hours. Those were the machines i was originally planning to buy... But they sold. Now im not sure what will happen... New machine or hold off for a decent used? Cost wise it was about 2k difference from the used (sold) machines to new.
    Dealer was pushing RFM. Whats the general consensus on them? Im thinking Mid mount for a bit of weight down low and for ease of use around the house (no tailswing)
    Dealer also said that hes had several people with BX's wanting to buy turfs this year. Said the Industrals were too hard on the wet ground? Thats another decision i need to consider.
    Quote Originally Posted by donn12 View Post
    Unfortunately the deere will have to go to finance the BX (or whatever machine).
    Honestly after seeing it in person, i think the B would be overkill most of the time. About the only time id like it is Bush hogging.
    Dealer wasn't endorsing a bush hog either. Said the BX had too little power according to the Landpride manual (20PTO recommended). Not sure what to make of that. I know guys here have them..But hes been selling tractors for 30 years so its not his first rodeo.
    He did say it'd pull a 4ft boxblade fine. That was good to hear.
    On a comparison note, What about the Massey GC24 or 26 TLB? They sell massey as well but he was really pushing the kubota. I thought the massey had stronger loader and backhoe (according to the brochures), but he didnt seem to agree....Theres also almost 2k between the kubota and the massey gc24.I was thinking the GC26 might be a better fit considering the occasional running of a Bush hog?
  9. #9
    Super Member CompactTractorFan's Avatar
    Join Date
    Jul 2010
    Posts
    7,935
    Pennsylvania
    Kubota BX25
    They do leave ruts on wet ground...
    Kyle - CompactTractorFan
    Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
    2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
  10. #10
    Elite Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    2,871
    From Vt, in Va, going to MS
    Kubota's - B7610, M4700
    Just remember the HST fan on the BX's.
    My rides - '95 Kubota M4700, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, 18', new Woods BH70-X w/ 16" bucket and Woods thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, Winco 12KW PTO generator with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 Hudson HSE Deluxe trailer - 5 Ton to haul
Similar Threads
  1. Diameter of the pins in a BX25 backhoe bucket
    By Tachdriver in forum Kubota Owning/Operating
    Last Post: 12-17-2010, 10:29 PM
  2. Backhoe 12" versus 16" Backhoe Bucket Size
    By Don_Curley in forum Kubota Owning/Operating
    Last Post: 07-27-2009, 04:12 PM
  3. Backhoe GC2410 Backhoe removal with jack?
    By bmarian in forum Massey Ferguson Owning/Operating
    Last Post: 06-28-2009, 08:39 AM
  4. Backhoe Can a BX2660 Be Fit w/ a Backhoe Later... like the BX25?
    By robertm in forum Kubota Owning/Operating
    Last Post: 05-27-2009, 09:13 AM
  5. Cab Backhoe Controls?
    By K7147 in forum Customization
    Last Post: 12-29-2006, 06:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
