Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
  1. #11
    Join Date
    Aug 2008
    Posts
    192
    SE Michigan
    Kubota BX 25
    Default Re: Wallenstein Chipper
    Quote Originally Posted by glennm View Post
    How fine is the mulch from the shredder? I would like to put some on trails in the bush
    It is fairly fine. I don't know where you live but around here (SE Michigan) I would only be putting chips from my Wallenstein on trails and not stuff that I had shredded with it. Shredded stuff would break down faster and be extra squishy in the spring. I use trails in the park system around here pretty regularly and they use coarse chips on those and it seems to work OK. The wet areas get new chips every year.
  2. #12
    Join Date
    Mar 2011
    Posts
    70
    Puslinch, Ontario
    BX23, RTV 900 and Z122
    It wouldn't be much different than the backhoe would it?
  3. #13
    Join Date
    Aug 2008
    Posts
    192
    SE Michigan
    Kubota BX 25
    Good point! I do often want to use the chipper without the loader on.
  4. #14
    Silver Member Kayakin2's Avatar
    Join Date
    Jan 2010
    Posts
    180
    Lakes Region, New Hampshire
    Kubota BX25
    My BX25 works great with my BX42 but I did learn I needed to adjust the blade gap to make my chips smaller. I went with the BX42 as some of my branches were tough. I do have a separate mulcher for leaves. Chips are great for paths and to throw into the compost! Enjoy!
    2010 Kubota BX25, Loaded R4s, BH (12"), 3PH, 60" Hyd Front Blade, Canopy, block heater, Landpride 50" Tiller & 54" Box Blade, Woods 60" Rake, 48" Tooth Bar, pallet forks and complete Bro-tek Package (BH thumb, Ripper/trenching plow, Wheel Spacers, Brush Forks, all skid plates), BXpanded Bucket Hooks, Wallenstein BX42, Agrex Spreader w/sand kit & Articulated Agitator.
    Toro Wheel Horse 268H, 42" Snowthrower, Snow Cab, rear blade, 17 cu. ft. Trailer, drop spreader & roller.
  5. #15
    Join Date
    Jan 2010
    Posts
    180
    Kubota BX25
    Here is a pic so you can see it in action!
    Attached Thumbnails Attached Thumbnails Wallenstein Chipper-bx25-bx42-chipper-action1-jpg
  6. #16
    Gold Member
    Join Date
    Sep 2010
    Posts
    482
    Two Harbors, MN
    A bit off topic but how do the chippers handle pine needles? What about serious pine "pitch/sap"? Does it get all junked up? How much would you have to do to maintain if you were cutting pine trees with lots of 1-2 inch branches?
    Thanks...looks pretty inviting...hate getting rid of branches.
    Do chip piles begin to be an issue?
    Thanks...TMR
  7. #17
    Join Date
    Mar 2009
    Posts
    713
    Quote Originally Posted by Kayakin2 View Post
    Can I ask what you set your blade gaps at?
  8. #18
    Join Date
    Jan 2010
    Posts
    180
    Kubota BX25
    Quote Originally Posted by MNBobcat View Post
    What do you gaps your blades at? Its supposed to be between 1/16 & 1/32 isn't it? Are you saying if I have a tractor with a lot of power I can go bigger (more than 1/32) on the gap?
    Actually, my BX42 arrived with a larger gap and I needed to reduce it to make the chips smaller and cut up more twigs. If you run at a high RPM, as suggested, the BX25 works fine!
  9. #19
    Join Date
    Jan 2010
    Posts
    180
    Kubota BX25
    I measured my gap at about 1/8" and adjusted it to about 1/20" (0.050") to try to cut up smaller branches.
  10. #20
    Join Date
    Aug 2008
    Posts
    192
    SE Michigan
    Kubota BX 25
    Quote Originally Posted by TMR View Post
    I have chipped up the branches from a few pine trees and had no problem with pitch build up affecting performance of the machine. It goes through 1-2 inch pine/spruce branches with NO problem. If I'm raking pine needles and put too much at a time in the shredder, the needles can slow things down a bit, but it is easy to adjust my "feed rate" for that.
    One thing I've mentioned before is that the shredder opening is fairly high off the ground. I'm 6'4". I could see feeding the shredder being a bit of a chore for less tall folks.
Similar Threads
  1. Chipper Wallenstein BX62 Chipper
    By Stonehaller in forum Attachments
    Last Post: 10-03-2013, 12:12 PM
  2. Wallenstein BX42 Chipper - chips into trailer?
    By MNBobcat in forum Attachments
    Last Post: 06-01-2011, 09:55 AM
  3. Chipper My New Wallenstein BX42 Chipper
    By dking in forum Attachments
    Last Post: 05-08-2009, 08:29 AM
  4. Chipper video - new wallenstein bx 42 chipper on Kubota bx 24
    By stump grinder in forum Attachments
    Last Post: 11-24-2008, 09:27 PM
  5. Chipper Wallenstein BX42 Chipper
    By cameron in forum Attachments
    Last Post: 05-15-2008, 12:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
